Hang-glider and water balloon problem
  • Thread starter Thread starter Karajovic
    Balloon Water
The problem involves a hang-glider dropping a water balloon from a height of 680.0 m while diving at an angle of 57.0 degrees with the vertical. The water balloon takes 5.20 seconds to reach the ground, and the original poster is attempting to determine the velocity of the hang-glider based on this scenario.
  • The original poster attempts to use kinematic equations to relate the hang-glider's velocity to the motion of the water balloon. Some participants question the correct trigonometric function to use based on the angle provided, leading to discussions about the relationship between angles and force components.
Participants are actively engaging in clarifying the use of sine and cosine in relation to the angle given with respect to the vertical. There is a productive exchange of ideas regarding the interpretation of angles and their implications for the calculations involved.
There is some confusion regarding the angle's reference point (vertical vs. horizontal) and how it affects the calculations. Participants are exploring the implications of using different trigonometric functions based on the angle's orientation.
Karajovic
A hang-glider, diving at an angle of 57.0o with the vertical, drops a water balloon at an altitude of 680.0 m. The water balloon hits the ground 5.20 s after being released.
a. What was the velocity of the hang-glider?
we know that the initial speed of the water balloon is the speed of the hang-glider... so:
∆y = vi(∆t)sinx - 1/2g∆t^2
680 = vi(5.2)sin57 - 1/2(-9.81)(5.2)^2
vi = 186 m/s
but my textbook says the answer is 193 m/s.
Is the book wrong? or am I wrong?
thanks!
Hi Karajovic! :smile:
so is it sin or cos? :wink:
(btw, are you ok on the other thread?)
Hey tiny-tim!
Thanks so much! I've been trying to find a solution for a while now! But may you please explain why you use cos?
Thanks again! (and I thought I replied to the other thread, but I guess it didn't send, I'll post there now!
Hey Karajovic! :smile:
You're probably used to being given the angle from the horizontal, in which case of course the horizontal component is cos, and the vertical component (which you need here) is sin.
The general rule is that it's always cos of the angle between the force and the direction.
So just ask yourself, is the given angle, θ, the angle between the force and the direction, or is it (90º - θ)?
Either way, it's cos … cosθ, or cos(90° - θ). :wink:
tiny-tim said:
Hey Karajovic! :smile:You're probably used to being given the angle from the horizontal, in which case of course the horizontal component is cos, and the vertical component (which you need here) is sin.
Argh... I don't get it... So, if you are given an angle with the horizontal, you use sin (but you said this is the vertical?) and if you are with the vertical, you use cos (which you said is the horizontal?)
What do you mean by the angle between the force and the direction?
(I put an attachment of a drawing... If angle B is 57, BC is 680 m and A is the direction of the hang-glider, which is the force? it can't be BC?)
Sorry if I may have created some confusion..
Thanks again!
I mean if you're asked for the component of a force in a direction,
it's always cos of the angle between that force and that direction.
Sometimes they give you the wrong angle (usually 90° minus the angle) …
then it's cos of the correct angle, which is sin of the angle they gave you. :smile:
Oh! I apologize, yes, know I understand! You can still use sin, but since the angle is with the vertical you would subtract it by 90 to get your horizontal angle..
so sin(90-x) = cosx (x is with the vertical) ?
Thank you! :smile:
