Perron formula for matrix powers
  • Context: Graduate
  • Thread starter Thread starter bpet
    Formula Matrix
The Perron formula for matrix powers is expressed as p_{ij}^{(n)} = \sum_{s=1}^r \frac{1}{(v_s-1)!}\left\{\frac{d^{v_s-1}}{d\lambda^{v_s-1}}\left[\frac{\lambda^nA_{ji}(\lambda)(\lambda-\lambda_s)^{v_s}}{|\lambda I_m-P|}\right]\right\}_{\lambda=\lambda_s}, where r represents the number of distinct eigenvalues and A_{ji}(\lambda) is the cofactor related to the determinant of the matrix. This formula applies to any matrix, not limited to Markov transition probabilities. The derivation may involve the Laplace transform of e^{tP} and the extraction of terms from the Taylor series, potentially using Laurent series and partial fraction expansion to find residues at infinity.
  • Understanding of matrix theory and eigenvalues
  • Familiarity with Laplace transforms and Taylor series
  • Knowledge of determinants and cofactors in matrices
  • Experience with Laurent series and partial fraction expansion
  • Research the derivation of the Perron formula in matrix analysis
  • Study the application of Laplace transforms in matrix exponentiation
  • Explore Gantmakher's Theory of Matrices for related concepts
  • Investigate Horn & Johnson's Matrix Analysis for general matrix functions
Mathematicians, researchers in linear algebra, and students studying matrix theory who are interested in advanced matrix functions and their applications.
bpet
The following interesting result popped up in an old probability textbook (without proof or citations) and I'm curious to know how it can be derived.
The elements [tex]p_{ij}^{(n)}[/tex] of matrix [tex]P^n[/tex] (size m) are also determined by the Perron formula
[tex]p_{ij}^{(n)} = \sum_{s=1}^r \frac{1}{(v_s-1)!}\left\{\frac{d^{v_s-1}}{d\lambda^{v_s-1}}\left[\frac{\lambda^nA_{ji}(\lambda)(\lambda-\lambda_s)^{v_s}}{|\lambda I_m-P|}\right]\right\}_{\lambda=\lambda_s}[/tex]
where [tex]r[/tex] is the number of distinct eigenvalues, [tex]\lambda_s[/tex] are the distinct eigenvalues with multiplicity [tex]v_s[/tex] (so [tex]v_1+\ldots+v_s=m[/tex]) and [tex]A_{ji}(\lambda)[/tex] is the cofactor of the elements [tex]\lambda\delta_{ji}-p_{ji}[/tex] in the determinant [tex]|\lambda I_m-P|[/tex] and [tex]I_m[/tex] is the identity matrix of the same size as P.
It seems to work for any matrix (not just Markov transition probabilities) and as far as I can tell it's not related to the Perron formula of number theory.
The term [tex]A_{ji}(\lambda)/|\lambda I_m-P|[/tex] would hint that [tex](\lambda I_m-P)^{-1}[/tex] is involved, so I suspect it's done by finding the Laplace transform of [tex]e^{tP}[/tex] and somehow extracting the nth term of the Taylor series. Is this on the right track and if so, how would it be done? In particular, how do they turn the expression into a sum of derivatives at the eigenvalues?
Have you managed to derive the formula yet? If I had time I'd love to have a go...
Anyway, I did a little searching and found
http://crypto.mat.sbg.ac.at/~ste/diss/node12.html
There he cites pg 16 of
V. Romanovsky, Discrete Markov Chains.
but I couldn't get a copy of it.
Thanks, me neither. I haven't checked the details but think it can be done by finding the residue of [tex]\lambda^n(\lambda I-P)^{-1}[/tex] at [tex]\lambda=\infty[/tex] via Laurent series and partial fraction expansion.
The formula was in Sveshnikov's Problems in Probability (as a "basic formula", not an actual problem). The result might be discussed in Gantmakher's Theory of Matrices or Horn & Johnson's Matrix Analysis, possibly even for more general matrix functions, though I don't have copies of these to check.
