[mathematica]- problem with the output
  • Context: Mathematica
  • Thread starter Thread starter sandoko
    Mathematica Output
The discussion centers on an issue with obtaining analytical eigenvalues from a matrix in Mathematica. Users often encounter outputs like Root[p,n], which represent the n-th root of a polynomial, instead of explicit numerical values. The solution provided involves using the ToRadicals function to convert these roots into a more understandable analytical form. This method successfully reveals the explicit forms of the eigenvalues, although the output can be extensive and complex.
  • Familiarity with Mathematica version 12.0 or later
  • Understanding of eigenvalues and eigenvectors in linear algebra
  • Knowledge of polynomial equations and their roots
  • Experience with Mathematica functions, specifically ToRadicals
  • Research the use of the ToRadicals function in Mathematica
  • Explore advanced eigenvalue problems in linear algebra
  • Learn about the Root function and its applications in Mathematica
  • Investigate methods for simplifying complex polynomial expressions in Mathematica
This discussion is beneficial for mathematicians, data scientists, and engineers who utilize Mathematica for computational tasks involving eigenvalues and require a deeper understanding of polynomial roots and their analytical representations.
sandoko
Hi everyone, i have a problem with mathematica. I am supposed to compute the eigenvalue of a matrix, and I need the expression for the eigenvalues analytically. But it output strange symbols. and I am unable to decipher what it means.
What I got is an output consisting of words like root and the symbol #. Can you guys explain to me why this happen. is there a way for me to obtain the analytical form all the time?
In Mathematica, when a polynomial is complicated enough it will sometimes return Root[p,n] for the n'th root of p[x] instead of the usually numbingly complicated root itself.
Rarely it is possible for Mathematica to find the actual root in that case.
Fortunately in your example if you evaluate
ToRadicals[Eigenvalues[A]]
you will find that it will give you the explicit form of the 3 complicated roots, the last root is zero.
Unfortunately I doubt you are going to be any happier with the 6.5 screenfulls at normal magnification that it takes to show the 3 complicated roots in explicit form. But now you have the analytical form for this particular problem.
oh, thanks for the the explanation especially the ToRadical command.. That's what I need. thanks!
  • · Replies 21 ·
