New Reply
Associates and their Norms
Share Thread Thread Tools
Oct13-10, 11:57 AM   #1
Hello PhysicsForums:
I have two things I'd like to learn more about:
1. I was noticing that the norms of +-1+-i (which are associates) are the same. The same goes for +-(1-2i). Is there a general reason explaining why any two integers which are associates have the same norm?
2. Assume that 'a' is a set of quadratic integers in Q[Sqrt(-3)] so that [tex]\bar{a}[/tex] and 'a' are associates. Can someone help describe what this set would be like when this occurs?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct13-10, 03:22 PM   #2
Recognitions:
Gold Membership Gold Member
1. It isn't true in general that associates have the same norm. For example, consider Q([itex]\sqrt{2}[/itex]). Then u = 1 + [itex]\sqrt{2}[/itex] is a unit. Let a = 2 + [itex]\sqrt{2}[/itex]. Then ua is an associate of a and ua = 4 + [itex]3\sqrt{2}[/itex]. However,
N(a) = (2 + [itex]\sqrt{2}[/itex])(2 - [itex]\sqrt{2}[/itex]) = 2,
but
N(ua) = (4 + [itex]3\sqrt{2}[/itex])(4 - [itex]3\sqrt{2}[/itex]) = -2
This fails because norms in Q([itex]\sqrt{2}[/itex]) can have negative values. However, if d < 0 and squarefree, then norms of elements in Q([itex]\sqrt{d}[/itex]) are [itex]\geq[/itex] 0. Then the norm of any unit = 1 and the product formula for norms implies that associates have the same norm.
2. I don't understand what you mean by the phrase so that [itex]\bar{a}[/itex] and 'a' are associates. Could you please elaborate? Thanks.
Oct13-10, 04:51 PM   #3
Quote by Petek View Post
but
1. Is saying that any two integers which are associates the same thing as saying two associates? I was referring to the Norm of these aforementioned integers being equal, not the norm of the associates being equal. (I hope that makes sense)
2. I meant to say that [itex]\bar{a}[/itex] and [itex]a[/itex] are associates. If I would re-write it:
Assume that [itex]a[/itex] is a set of quadratic integers in Q[Sqrt(-3)] so that [itex]\bar{a}[/itex] and [itex]a[/itex] are associates. Can someone help describe what this set would be like when this occurs?
Oct13-10, 06:12 PM   #4
Recognitions:
1. You originally observed that (1 + i) and -(1 + i) were associates and had the same norm (that's not exactly what you wrote, but I think is what you meant). You also observed that (1 -2i) and -(1 -2i) were associates and had the same norm. You wondered whether there was an explanation why any two integers that were associates had the same norm. I gave an example that showed this wasn't always true. However, I pointed out that your statement was true if the norm of any integer was non-negative. Here's how to prove that:
First, it's easy to see that, in general, the norm of a unit must be either +1 or -1. Since we're assuming that all norms are non-negative, then any unit must have norm = 1. Now suppose that a and b are associates. Then there exists a unit u such that a = ub. Therefore,
N(a) = N(ub) = N(u) N(b) [Product rule for norms] = N(b)
since N(u) = 1. It remains to show that if d < 0, then the norm of any integer in Q([itex]\sqrt{d}[/itex]) is non-negative. That's a simple calculation.
I hope this makes my previous post more clear.
2. [itex]a[/itex] is a set, not a number, so you need to define what you mean by [itex]\bar{a}[/itex] and what you mean by two sets being associates. I could try to guess, but prefer that you give your definition. I'm not trying to be obstinate, but your usage isn't standard, AFAIK.
Oct13-10, 09:32 PM   #5
First off, thank you for explaining that 1st point to me, I really appreciate it!
2. [tex]\bar{a}[/tex] is simply the conjugate of [itex]a[/itex]. It is to my understanding that since [itex]a[/itex] is a set of quadratic integers of the form [itex]a+b*\sqrt{-3}[/itex], that [itex]\bar{a}[/itex] would be a set of integers of the form [itex]a-b*\sqrt{-3}[/itex].
Associate: If [itex]\alpha[/itex] and [itex]\beta[/itex] are non-zero integers in [itex]Q[\sqrt{d}][/itex] such that [itex]\alpha = \beta*\epsilon[/itex], where [itex]\epsilon[/itex] is a unit, then [itex]\alpha[/itex] is said to be an associate of [itex]\beta[/itex]. In other words, [itex]\alpha[/itex] is only an associate of [itex]\beta[/itex] if and only if [itex]\alpha / \beta[/itex] is a unit.
Oct14-10, 12:33 PM   #6
Recognitions:
Is this your question?
Let a be an integer in Q([itex]\sqrt{-3}[/itex]). Under what conditions is [itex]\bar{a}[/itex] an associate of a?
If so, start by describing both the integers and units of Q([itex]\sqrt{-3}[/itex]). Hint: There are more of them than you might think.
Oct14-10, 12:48 PM   #7
No, I already know what an associate is. I'm simply saying this:
If [itex] a [/itex] is a set of quadratic integers in Q([itex]\sqrt{-3}[/itex]) and [itex]\bar{a}[/itex] is the associate set of quadratic integers with respect to [itex] a [/itex], what would the set of quadratic integers in [itex] a [/itex] have to look like? I essentially would like to know a description of [itex] a [/itex].
Oct14-10, 04:11 PM   #8
Recognitions:
Let's fix some notation. Perhaps that will help me to understand your question.
Let K = Q([itex]\sqrt{-3}[/itex]).
Let [itex]O_{K}[/itex] denote the integers of K.
Also, let's use uppercase letters to denote sets and lowercase to denote elements of sets.
Let A [itex]\subseteq\\O_{K}[/itex] (A is a subset of the integers of K.)
Let [tex]\overline{A}[/tex] = {[tex]\bar{a}[/tex]: a [tex]\in[/tex] A} (the set of conjugates of elements in A)
Let A~ = {ua: a[tex]\in[/tex]A and u is a unit in [tex]O_K[/tex]} (the set of all associates of elements in A)
As I understand it, you want A to be a subset of integers in K that satisfies certain relationships with its set of conjugates and set of associates. Is that correct? If so, what is the relationship?
Oct14-10, 10:25 PM   #9
You are correct. I don't know what you mean by asking me what is the relationship. I'm trying to determine what the set of [itex] A [/itex] will be like though so that the conditions are met.
Oct14-10, 11:15 PM   #10
Recognitions:
Let me rephrase your original question using the above notation:
Assume that A [tex]\subseteq \\ O_K[/tex] is such that [tex]\overline{A}[/tex] and A are associates. Can someone help describe what this set would be like when this occurs?
So the condition on the set A is that "[tex]\overline{A}[/tex] and A are associates." In a prior post, I asked for your definition of what it means for two sets to be associates. You replied with the definition of what it means for two integers in [itex]O_K[/itex] to be associates. So, suppose that A and B are subsets of [itex]O_K[/itex]. Then A and B are said to be associates if ... . Please supply the rest of the definition*. I know what it means for two numbers to be associates, but not what you mean by saying that two sets are associates. Thanks.
* For example, a possible definition would be that A and B are said to be associates if for every a [itex]\in[/itex] A, there exists a b [itex]\in[/itex] B such that a and b are associates.
Oct15-10, 12:01 AM   #11
That is exactly what I'm saying! :-)
Oct15-10, 02:55 PM   #12
Recognitions:
Quote by Brimley View Post
Good! So let's define A = {a [itex]\in O_K[/itex]: a is an associate of some element in [tex]\overline{A}[/tex]}
Now, try to prove the following:
1. Any rational integer (that is, any element of Z) belongs to A.
2. Any unit in [itex]O_K[/itex] belongs to A.
3. 1 + [itex]\sqrt{-3} \in[/itex] A.
Can you find any other elements of A?
Oct15-10, 03:08 PM   #13
+-1 (Units)
[itex]+-1+*\sqrt{-3}[/itex]
+-2
[itex]+-\sqrt{-3}[/itex]
I believe those all work, and I know that each shown above and its negative are associates, however [itex]1 +*\sqrt{-3}[/itex] and [itex]1 - \sqrt{-3}[/itex] are not associates.
Oct15-10, 04:23 PM   #14
Recognitions:
You need to work on your notation: That extra i isn't necessary. And, 1 + [itex]\sqrt{-3}[/itex] and 1 - [itex]\sqrt{-3}[/itex] are associates. There are 6 units in [itex]O_K[/itex]. Two are +1 and -1. Can you find the other 4?
Oct15-10, 04:26 PM   #15
My bad! I totally goofed that up, but I'm glad you knew what I meant.
Perhaps 2 of them are 0+-i ? I'm not sure what would the others be.
Oct15-10, 06:47 PM   #16
Recognitions:
No problem. I'll be mostly offline for the next few days. Take a look at the Wikipedia articles on Quadratic Integers and Eisenstein Integers. Use the article on Quadratic Integers to determine the elements of [itex]O_K[/itex]. Figure out why the Eisenstein integers are relevant to your situation. I'll check back next week to see how you did. Perhaps someone else will add to the discussion.
Oct16-10, 02:11 AM   #17
If someone could help me with this, I'd really appreciate it. I looked at those Wiki's and I was totally lost.
New Reply
Thread Tools
Similar Threads for: Associates and their Norms
Thread Forum Replies
Proof of associates in Zp[x] Calculus & Beyond Homework 6
Prove that Associates Have the Same Norm Calculus & Beyond Homework 3
mrjeffy and associates... Chemistry 3
