Thread Closed
Derive a formula for momentum in terms of kinetic energy
Share Thread Thread Tools
Oct14-10, 03:54 AM   #1
Using:
particle velocity, beta
particle momentum, p
total energy, E
Lorentz factor, gamma
kinetic energy, KE
Derive an equation for momentum as a function of kinetic energy. The functions have to depend either on the variable in the bracket, p(KE), or on a constant.
3. The attempt at a solution
This is what I've done so far, and I am now stuck, and unsure if the way I am doing it is correct or if there is a different approach.
[tex]E^{2} = p^{2}c^{2} + m^{2}c^{4}[/tex]
[tex]KE = E - m_{0}c^{2}[/tex]
[tex]KE = \sqrt{p^{2}c^{2} + m^{2}c^{4}} - m_{0}c^{2}[/tex]
[tex]p^{2} = \frac{KE^{2}}{c^{2}} - m^{2}c^{2} - m_{0}^{2}c^{4}[/tex]
The only thing I could think of doing next is:
[tex]KE = \frac{p^{2}}{2m_{0}} , m_{0} = \frac{p^{2}}{2KE}[/tex]
[tex] p^{2} = \frac{KE}{c^{2}} - m^{2}c^{2} - \frac{p^{4}}{4KE^{2}}c^{2}[/tex]
[tex]p^{2} + \frac{p^{4}}{4KE^{2}}c^{2} = \frac{KE}{c^{2}} - m^{2}c^{2}[/tex]
[tex]p^{2}(1 + \frac{p^{2}}{4KE^{2}}c^{2}) = \frac{KE}{c^{2}} - m^{2}c^{2}[/tex]
I'm not sure if this is the best or easiest way to do this, as it seems to be pretty messy, and I also have one more m in the equation that I need to get rid of but am not sure of the best way of doing so.
Any help will be greatly appreciated :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct15-10, 03:28 AM   #2
Ok, so I've been working on this problem for about 24 hours and I think I'm finally getting somewhere with it. In class we were given a sheet of useful formulae, and this included:
[tex] p = \gamma \beta m_{0} c = \frac{m_{0} \beta c}{\sqrt{1 - \beta^{2}}} [/tex]
[tex] = \frac{\sqrt{E_{tot}^{2} - m_{0}^{2}c^{4}}}{c} [/tex]
From this final equation, I noticed that
[tex] KE = \sqrt{E_{tot}^{2} - m_{0}^{2}c^{4}} [/tex]
So this means that I have the relation:
[tex]p = \frac{KE}{c} [/tex]
Which is momentum which is only dependent on KE or a constant!
The only problem I have now is working out where that equation from p comes from, can anybody help?
Oct15-10, 03:43 AM   #3
Recognitions:
Gold Membership Gold Member
The formula for the momentum is derived from the expression for total relativistic energy. This page has some good info:
http://hyperphysics.phy-astr.gsu.edu...iv/releng.html
Oct15-10, 03:50 AM   #4
Great, finally I've figured it all out! Thank you for your help! :)
Thread Closed
Thread Tools
Similar Threads for: Derive a formula for momentum in terms of kinetic energy
Thread Forum Replies
Can anybody explain the formula for Kinetic Energy? Classical Physics 26
formula of kinetic energy General Physics 1
Relativistic kinetic energy formula General Physics 0
Please help, Express kinetic energy in terms of m and p? Introductory Physics Homework 2
