How Can You Solve an Integral with a 2nd Order Pole on the Real Axis?
The discussion revolves around evaluating a complex integral involving a second-order pole on the real axis, specifically the integral of the function (cos(b*x)-cos(a*x))/(x^2) over the interval from -Infinity to Infinity. Participants explore methods from complex analysis to address the challenges posed by the pole's order.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of related integrals and the implications of having a second-order pole, with some suggesting integration by parts to simplify the integrand. Others propose examining the integral of a modified function in the upper half-plane and considering residue calculations.
The discussion is ongoing, with participants providing various approaches and sketches of potential solutions. There is acknowledgment of differing interpretations of the integral's behavior, particularly regarding the signs and the treatment of singularities.
Some participants note the complexity introduced by the second-order pole and the need for careful consideration of singularities and residue contributions. The original poster expresses uncertainty about how to proceed given the constraints of the problem.
gysush
I'm working on a complex analysis problem from Arfken.
Integrate[ (cos(b*x)-cos(a*x))/(x^2), {x, -Infinity, Infinity}]
and show that it is equal to Pi*(a-b)
Attempt:
I first look at a related problem (or one that I think is related).
=> f(x) = sin(x)/x
=> f(z) = sin(z)/z
For this problem I can look at P[Integral(f(z)dz)]
then...sin(z)/z = [exp(i*z) - exp(-i*z)]/2*i*z = Integral 1 - Integral 2
where Integral 1 is the +i and Integral 2 is -i => this determines if we should close our contour in the UHP or LHP
Then Integral 1 = P[exp(i*z)/2*i*z] = Pi*i*Res(f(0))
Res(f(0)) is simple to calculate => 1/2*i
Likewise, Integral 2 = P[exp(-i*z)/2*i*z] = -Pi*i*Res(f(0))
Then Integral 1 - 2 = Pi*i/2*i - (-Pi*i/2*i) = pi
Upon inspection of my original integral I realize I have a 2nd order pole on the axis instead of a simple pole. Prof said the above method is only valid for simple poles. I then examine my notes/boas/arfken/leia for an example of 2nd order pole on real axis as in this problem...but have not been successful.
One example that I see is of form f(cos,sin)/(x^2 - a^2) which has two simple poles at a and -a
Another is of the form f(cos,sin)/(x^2 + a^2) which has two simple poles at +/- ia
For this integral, do not need principal value. We can consider, i.e. sin/(x^2 + a^2)...and from there calculate Integral[exp(iz)/z)...and set it equal to sum of residues etc...then separate out im/real parts and math them on LHS and RHS.
I'm kinda lost on the problem that I originally posted...
Try integrating by parts once to get an integrand with only a simple pole.
Thank you!
I'll give you a quick sketch. Perhaps you can go through it and fill in the details. Also, that's a removable singularity in the original problem. But how about considering the integral:
[tex]\int_C \frac{e^{iaz}-e^{ibz}}{z^2}dz[/tex]
where C is the half-disc in the upper half-plane with an indentation around the now simple pole. We would then have:
[tex]\int_{-\infty}^0+\int_{\Gamma}+\int_{0}^{\infty}+\int_U=0[/tex] so that (after some justification):
[tex]\int_{-\infty}^{\infty}+\int_{\Gamma}=0[/tex]
where the integral over U is the half-circle arc and gamma is the indentation at the origin and that is just [itex]-i\pi r[/itex]
where:
[tex]r=\mathop\text{Res}_{z=0}\left\{\frac{e^{iaz}-e^{ibz}}{z^2}\right\}=i(a-b)[/tex]
I'm assuming the sine terms drop out because they are odd but I've not gone through this carefully and the integral over the large semi-circle tends to zero but I've not checked that.
So assuming all that is ok, then we have:
[tex]\int_{-\infty}^{\infty}=-\pi(a-b)=\pi(b-a)[/tex]
Note I'm getting a minus sign different from yours. You can look into that. I left out details that you can go through.
Yes, thank you as well. But the answer fell out almost trivially (since I already know Integral[sinx/x] once I did the integration by parts. Just had to make sure I took out the b or the a once I diff cos(ax)
  • · Replies 19 ·
