Understanding Partial Differentiation in Classical Mechanics
The discussion revolves around the concept of partial differentiation in the context of classical mechanics, focusing on the mathematical treatment of functions dependent on multiple variables, particularly in relation to derivatives and their interpretations.
  • One participant expresses confusion regarding the differentiation of a function L(x, x*) and questions why the partial derivative with respect to x does not include a term for the derivative of x* with respect to x.
  • Another participant clarifies that in this context, x and x* are treated as independent variables when differentiating.
  • A participant questions the validity of taking a partial derivative with respect to a variable that is not explicitly defined, suggesting that it may lead to inconsistencies.
  • There is a discussion about the implications of expressing velocity as a function of generalized coordinates and how this relates to the definition of partial derivatives.
  • One participant mentions a concept referred to as "dot cancellation" in relation to the derivatives of position and velocity vectors, but expresses uncertainty about its application.
  • Clarifications are made regarding the notation used for variables, with one participant noting the absence of p's in their discussion, focusing solely on q's as the independent variables.
Participants exhibit uncertainty and confusion regarding the definitions and applications of partial derivatives in this context. There is no clear consensus on the interpretation of certain derivatives or the implications of treating variables as independent.
Some participants express limitations in their understanding of the definitions and relationships between variables, particularly in the context of classical mechanics and the treatment of derivatives.
nonequilibrium
Hello,
I got confused in my Classical Mechanics class (on a mathematical issue). So let [tex]L[/tex] denote a function dependent on x and its derivative explicitly, such that its image is [tex]L(x,x*)[/tex] (NOTE: I'm using * as the overdot-Leibniz notation for the derivative) and x is a function of t.
To make it easy, I'll give an explicit form [tex]L(x,x*) = Ax + Bx*[/tex]. Now I found it odd that [tex]\frac{\partial L}{\partial x} = A[/tex] instead of [tex]\frac{\partial L}{\partial x} = A + \frac{\partial x*}{\partial x}[/tex]... What is the reasoning behind this? Is it because L is an explicit function of x* too? Or is it because x* is not explicitly dependent of x? Well it's quite probable that x* is physically dependent on x (only not the case when x is a linear function of degree 1 or 0), but for some reason mathematically it isn't(?)
Hello mr. vodka! :smile:
Yup, that's it …
L is specially defined mathematically
when you differentiate, x and x* are treated as independent variables. :wink:
So, for example, in general it's true that
[tex]\frac{\partial f(x,y,z)}{\partial \frac{dx}{dt}} = 0[/tex]
EDIT: Hm, re-reading my post, my question doesn't seem to make a lot of sense: you can't take a partial derivative wrt something that isn't explicitly a variable. By definition of partial derivative: I'm holding x,y,z constant and letting dx/dt variate... I don't know if that is even consistent, but the first part of my sentence would imply that ... = 0. On the other hand, I could also write down [tex]\frac{\mathrm{d} f(x,y,z)}{\mathrm{d} \frac{dx}{dt}}[/tex]; is this also zero?
EDIT2: In my classical mechanics course, v_i is a function of q_j's. Then it makes a statement about [tex]\frac{\partial v_i}{\partial \frac{\mathrm d q_j}{\mathrm d t}}[/tex] Is this even well-defined? A partial derivative is only defined wrt explicit variables...
If f isn't a function of ∂x/∂t (as well as of x y and z), that doesn't make much sense.
oh … just seen your edit … you beat me to it! :biggrin:
(and messing about with d instead of ∂ is never gong to happen in practice. :wink:)
If v is expressed as a function of qs only, that really means it's a function of qs and dq/dts, but it's constant in the dq/dts.
(i'll post quickly before he does another edit! :rolleyes:)
Thanks for the diligent help!
I'm not sure what you mean with "but it's constant in the dq/dts".
Wouldn't that imply that [tex]\frac{\partial v_i}{\partial \frac{\mathrm d q_j}{\mathrm d t}} = 0[/tex]? However, in my course, there is stated that it's equal to [tex]\frac{\partial r_i}{\partial q_j}[/tex] (called dot cancellation, apparently -- I'll assume that by now you've figured out r is the position vector and v the velocity)
Now I'm totally confused as to what v is. :confused:
My apologies: v is the velocity vector, i.e. [tex]\vec v_i = \frac{\mathrm d \vec r_i}{\mathrm d t}[/tex]. The q_j's are the (independent) variables on which r_i (and thus v_i) are dependent (along with explicitly/implicitly time t). Note: I left out the vector notation for v and r in previous posts due to laziness.
EDIT: perhaps this is a question best asked in a physics forum?
I'm used to seeing ps and qs as the variables …
which are the ps in your notation? :confused:
(sorry for the delay … i thought i'd pressed "Submit Reply", but i hadn't :redface:)
Hm, did I use p's somewhere? There are no p's, only the q's are the variables.
i.e.:
[tex]\vec r_i : R^n \to R^3: (q_1,q_2, ...,q_n) \to \vec r_i(q_1,q_2, ...,q_n)[/tex]
And by definition of derivative:
[tex]\vec v_i : R^n \to R^3: (q_1,q_2, ...,q_n) \to \frac{\mathrm d \vec r_i}{\mathrm d t}(q_1,q_2, ...,q_n)[/tex]
  • · Replies 16 ·
