Finding Thevenin eq of this circuit
  • Thread starter Thread starter The_Lobster
    Circuit Thevenin
The discussion focuses on finding the Thevenin and Norton equivalent circuits for a specific circuit as viewed from terminals AB. The Thevenin equivalent consists of a voltage source in series with a resistance, calculated by setting independent sources to zero and finding the equivalent resistance. The Thevenin voltage is determined using node voltage analysis, leading to the equation (V_th - 15)/R_s + V_th/R_1 + V_th/R_2 = 0. The Norton equivalent is derived through a source transformation, resulting in a current source in parallel with a resistor, where R_n equals R_th and I_n is calculated as V_th / R_th.
  • Understanding of Thevenin and Norton theorems
  • Familiarity with circuit analysis techniques, including node voltage analysis
  • Knowledge of series and parallel resistor combinations
  • Basic proficiency in electrical engineering concepts
  • Study Thevenin's theorem applications in complex circuits
  • Learn about Norton’s theorem and its practical applications
  • Explore advanced circuit analysis techniques, such as mesh analysis
  • Investigate the use of simulation tools like LTspice for circuit analysis
Electrical engineering students, circuit designers, and professionals involved in circuit analysis and design will benefit from this discussion.
The_Lobster
There's a problem in my book where it asks me to find the Thevenin and Norton equivalent circuit of the attached circuit, as viewed from AB. I believe I know the answer, but just had to check to be sure this is not a trick question?
Isn't the Thevenin eq. circuit as seen from AB exactly the one drawn, without R1 and R2? And the Norton one just a source transformation from the one we see?
Thanks in advance!
A thevenin equivalent circuit is always a voltage source in series with a resistance. To get the thevenin resistance, you set all independent sources to zero (short voltage source, open current source), and find the equivalent resistance in reference to the terminals. So in reference to the terminals AB, we have R_th = R_s // R_1 // R2 = (R_s*R_1 + R_s*R_2 + R_1*R_2)/(R_s + R_1+R_2). To get thevenin voltage, we can easily find by finding the voltage across whatever is in parallel with the terminals, which can be either R_1 or R_2. Doing a simple node equation at A, calling A V_th, and calling B ground, (V_th - 15)/R_s + V_th/R_1 + V_th/R_2 = 0. Solve for V_th.
EDIT: For Norton equivalent, you simply do a source transformation. Norton equivalent is a current source in parallel with a resister. R_n = R_th. I_n = V_th / R_th
  • · Replies 22 ·
