What is the Partition Function for a Singular Exponential Hamiltonian?
  • Thread starter Thread starter jarvGrad
The discussion centers on calculating the partition function for a singular exponential Hamiltonian defined by the equation H = Σ{(x_n + dy_n)^2} < 2mE. The integral of interest is Z = ∫ exp[ax^2 + bxy + cy^2] d^{3n}x d^{3n}y, where the matrix A = [a b; b c] becomes singular due to the specific form of the Hamiltonian, x^2 + 2mwyxy + (mwy)^2. The participant notes that a simple variable change and integration over a hypersphere is sufficient for multiplicity calculations, and emphasizes that the partition function approach is necessary for this problem.
  • Understanding of Hamiltonian mechanics
  • Familiarity with multivariable calculus and integrals
  • Knowledge of matrix theory, specifically determinants
  • Concept of partition functions in statistical mechanics
  • Study the method of change of variables in integrals
  • Learn about hyperspherical coordinates and their applications
  • Explore the concept of singular matrices and their implications in physics
  • Investigate the role of partition functions in statistical mechanics
Physicists, particularly those specializing in statistical mechanics and quantum mechanics, as well as graduate students working on advanced topics in Hamiltonian systems.
jarvGrad
I need to find the integral as follows:
I am given a Hamiltonian of the form:
[tex]\<br /> <br /> H=\Sigma {(x_n+d y_n)^2}< 2 m E<br /> [/tex]
(This should be a sum over n, but its not showing in the preview)
we integrate the exponential in n-space as
[tex]\<br /> \begin{equation}<br /> \int \exp{H} d^{3n}x d^{3n}y<br /> \end{equation}[/tex]
so that
[tex]\<br /> \begin{equation}<br /> \int \exp{(x+dy)^2} d^{3n}x d^{3n}y<br /> \end{equation}[/tex]
where (x+dy)^2 < E
I found a solution that tells me
[tex]\<br /> \begin{equation}<br /> \int \exp{(ax^2+bxy+cx^2)^2} d^{3n}x d^{3n}y<br /> \end{equation}[/tex]
which equals
[tex]\<br /> \begin{equation}<br /> \pi^{m/2}/{det[A]} <br /> \end{equation}[/tex]
where A is the 2-D matrix
A=[a b
b c]
However, the determinant is zero as I am given
[tex]\<br /> <br /> x^2+2mwxy+(mwy)^2<br /> <br /> [\tex]<br /> <br /> so this doesn't work. I found this solution at <a href="http://srikant.org/thesis/node13.html" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://srikant.org/thesis/node13.html</a> .<br /> There is a bit more work shown on the website. My professor assured me that the solution is closed form.[/tex]
Do you mean
[tex] \<br /> \begin{equation}<br /> \int \exp{(ax^2+bxy+cy^2)^2} d^{3n}x d^{3n}y<br /> \end{equation}<br /> [/tex]
Why not diagonalise A by doing a change of variables in you integral, or possibly a proof by induction?
Oops sorry I miss wrote the integral in one of the lines above. It should read
[tex]\<br /> Z=\int exp[ax^2+bxy+cy^2] d^{3n}x d^{3n}y[/tex]
my problem happens to be specified that the exponential is of the form
\\x^2+(m w y)^2 + 2mwxyThis makes the matrix in the above solution singular and the integral cannot be performed.
Note the problem that I was working on should not be solved like this. All I needed to do for that problem was do a simple variable change and integrate over a hypersphere described by the Hamiltonian. Not the exponential of the Hamiltonian. It is the usual integration one performs for multiplicity calculations. But another way to solve this problem is to calculate the partition function instead of the multiplicity. This calculation involves the partition function, which is denoted Z above.
  • · Replies 19 ·
