Calculating Time for Window Shade Roll-Up: M, W, L, T, R, m, g Dynamics
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
    Dynamics Window
The discussion focuses on calculating the time it takes for a window shade of mass M, thickness W, and length L to roll up completely when released from its unfurled position, driven by a linear spring with tension T. The problem involves determining the radius of the cylinder plus shade system and integrating the radius function to find the length around the cylinder. The moment of inertia must be calculated based on the angle-dependent thickness of the shade, and the forces acting on the cylinder must be analyzed using Newton's second law. A numerical solution is recommended due to the nonlinearity of the equations involved.
  • Understanding of Newton's second law
  • Familiarity with moment of inertia calculations
  • Knowledge of integration techniques for radius functions
  • Experience with numerical methods for solving nonlinear equations
  • Study the integration of radius functions in mechanical systems
  • Learn about calculating moment of inertia for composite shapes
  • Explore numerical methods for solving nonlinear differential equations
  • Investigate the dynamics of spring systems in mechanical applications
Mechanical engineers, physics students, and anyone involved in the design or analysis of mechanical systems, particularly those dealing with spring dynamics and rotational motion.
Loren Booda
A window shade of mass M, thickness W and length L is driven by a linear spring having tension T (with shade unfurled) and tension 0 (with shade rolled up). The solid cylinder upon which the shade winds has radius R and mass m. What is the time elapsed for the shade to roll up completely when released from its unfurled position? Assume zero friction and gravitational acceleration g.
To the best of my knowledge, this gets real ugly. The equations are easy to obtain, but because of their nonlinearity you'll have a hard time solving them. I think a numerical solution would more appropriate for this problem. I can however point you in the right direction.
First, you need to determine how the shade rolls around the cylinder: radius of the (cylinder + shade) system while it's rolling and length around the cylinder for any angle. The length is obtained by integrating the radius function.
Next, calculate the (angle dependent) moment of inertia. Fairly easy once you know the thickness of the shade on the cylinder.
Finally, find the expressions for the forces acting on the cylinder (weight of remaining shade and spring). Don't forget they depend on the angle. Plug them in Newton's 2nd law:
[tex] I\left( \theta \right)\ddot \theta = \sum {\tau \left( \theta \right)} [/tex]
You now need to solve the resulting equation. Not easy.
That's about it. If you need some more details (like equations), let me know :smile:
Thanks, mu. I got my inspiration while tugging the shade of my bathroom window. Such a mundane process, fairly easily stated, but hard as heck to solve - one needs a computer. I am aware of the basic equations, just stumped on how they are ultimately coupled (nonlinearly).
  • · Replies 45 ·
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 0 ·
