Equation of motion for interacting fields
The discussion centers on deriving the equations of motion for 2N classical, real, scalar fields \(\phi_i(x^{\nu})\) and \(\psi_i(x^{\nu})\) using the provided Lagrangian density \(L\). The Lagrangian includes an interaction term represented by \(-\lambda \phi_i \psi_i\). The initial attempt at a solution incorrectly disregarded this interaction term, leading to the identification of the equations as the Klein-Gordon equation. The correct approach is to apply the Euler-Lagrange equation to the full Lagrangian, including the interaction term, to obtain the accurate equations of motion.
  • Understanding of Lagrangian mechanics
  • Familiarity with the Euler-Lagrange equation
  • Knowledge of scalar fields in quantum field theory
  • Basic concepts of field interactions
  • Study the derivation of the Euler-Lagrange equation in detail
  • Explore the implications of interaction terms in field theories
  • Learn about the Klein-Gordon equation and its applications
  • Investigate perturbation theory in quantum field theory
Physicists, particularly those specializing in quantum field theory, students studying classical mechanics, and researchers interested in field interactions and their implications in theoretical physics.
>>S/Z<<
2N classical, real, scalar fields \phi_i (x^{\nu}) \psi_i (x^{\nu}) ,where i=1,...,N
I have to find the equations of motions for \phi_i (x^{\nu}) \psi_i (x^{\nu})
Lagrange density is given by
L= \sum_{i=1}^N (\frac{1}{2}(\partial_{\mu} \phi_i \partial^{\mu} \phi_i+\partial_{\mu} \psi_i \partial^{\mu} \psi_i-m^2(\phi_i \phi_i + \psi_i \psi_i) - \lambda \phi_i \psi_i))
\partial_{\mu} \frac{\partial L}{\partial (\partial_{\mu} \phi_i)} - \frac{\partial L_0}{\partial \phi_i} = 0
The problem for me is the interaction term? Can I just put in the Euler-Lagrange equation as well, or what do I do with it? I found some equations by disregarding the interaction term
\partial_{\mu} \partial^{\mu} \phi_i + m^2 \phi_i = 0
\partial_{\mu} \partial^{\mu} \psi_i + m^2 \psi_i = 0
Is this right?
It's easier to read the math if you actually wrap it in [tex ] and [ /tex] tags :wink: I've done that in the quote below for everyone's reference:
>>S/Z<< said:
2N classical, real, scalar fields [itex]\phi_i (x^{\nu})[/itex], [itex]\psi_i (x^{\nu})[/itex], where i=1,...,N
I have to find the equations of motions for [itex]\phi_i (x^{\nu})[/itex], [itex]\psi_i (x^{\nu})[/itex]
[tex]L= \sum_{i=1}^N (\frac{1}{2}(\partial_{mu} \phi_i \partial^{\mu} \phi_i+\partial_{mu} \psi_i \partial^{\mu} \psi_i-m^2(\phi_i \phi_i + \psi_i \psi_i) - \lambda \phi_i \psi_i))[/tex]
[tex]\partial_{\mu} \frac{\partial L}{\partial (\partial_{\mu} \phi_i)} - \frac{\partial L_0}{\partial \phi_i} = 0[/tex]
[tex]\partial_{mu} \partial^{\mu} \phi_i + m^2 \phi_i = 0[/tex]
[tex]\partial_{mu} \partial^{\mu} \psi_i + m^2 \psi_i = 0[/tex]
Is this right?
You may recognize the equations you found as the Klein-Gordon equation which governs the evolution of a free scalar field. So it is exactly what you'd expect to find if you discard the interaction term, i.e. pretend that the fields do not interact. But it's not the answer you need. You can't just disregard that term and pretend that it doesn't change anything.
Just include the interaction term in the Lagrangian, as you do with the other terms.
Sorry about that! My first post so not familiar with it all yet
Okay so just use the Euler-Lagrange equation on the full Lagrange.
Thanks for the reply:)!
  • · Replies 18 ·
