How to Find Parametric Equations for a Perpendicular Line?
  • Context: Undergrad
  • Thread starter Thread starter matpo39
    Lines Vector
The discussion focuses on deriving parametric equations for a line that passes through the point (0,1,2) and is perpendicular to the line defined by the parametric equations x=1+t, y=1-t, z=2t. The direction vector of the given line is identified as vector_v = <1,-1,2>. A perpendicular direction vector, vector_n = <-2,2,2>, is calculated using the cross product of vector_v and another vector, vector_r = <1,1,0>. The resulting parametric equations for the perpendicular line are x=-2t, y=1+2t, z=2+2t.
  • Understanding of parametric equations in three-dimensional space
  • Knowledge of vector operations, including cross product and dot product
  • Familiarity with the concept of perpendicular vectors
  • Basic skills in manipulating algebraic expressions
  • Study vector operations in depth, focusing on cross products and their geometric interpretations
  • Learn how to derive parametric equations from given points and vectors
  • Explore the concept of lines and planes in three-dimensional geometry
  • Practice solving problems involving perpendicular lines and their equations
Students and educators in mathematics, particularly those studying geometry and vector calculus, as well as anyone interested in understanding the relationships between lines in three-dimensional space.
matpo39
hi, I am having a bit of trouble with this problem
Find the parametric equations for the line through the point(0,1,2) that is perpen dicular to the line x=1+t, y=1-t, z=2t and intersects this line.
first i seen that i have a direction vector from the given parametric eqations which is
vector_v= <1,-1,2> and i can get the parallel line to that by taking <1,1,0>,which i will call vector_r, also from the parametric equations.
then to find a line perpendicular to this i take (vector_v) x (vector_r)
(vector_v) x (vector_r) = <-2,2,2>=vector_n
taking point(0,1,2) and vector_n i get
<0,1,2> + t<-2,2,2> = (0-2t)i+(1+2t)j+(2+2t)k =
x=-2t , y=1+2t , z= 2+2t
i was wondering if this is how you would go about solving this problem, if not a push in the right direction would be great.
thanks
well you are looking for a point on the given line that, when joined to the given point, makes a vector perpendicular to the given line.
you have a general point on the given line as (1+t, 1-t,2t) so you know how to subtract it from the given point and then how to dot the result with the direction vector of the given line i guess. that should do it.
sorry i ignored everything after your first three lines.
ok, i just want to make sure i got this, when i subtracted the point (0,1,2) from (1,1,0) which came from the parametric equation. and got <-1,0,2>
then i doted that with the direction vector from the parametric equation which is <1,-1,2> and got <-1,0,4>.
is that right so far? and how would i get a parametric equation from just one vector?
thanks
  • · Replies 25 ·
