Photons reflecting off mirrors, wheres the flaw?
  • Context: Graduate
  • Thread starter Thread starter Sakha
    Mirrors Photons
The discussion revolves around the behavior of photons reflecting off mirrors in a hypothetical scenario involving two spacecraft in space. Participants explore concepts related to momentum transfer, conservation of energy, and the implications of redshift in this context. The conversation touches on theoretical aspects, mathematical modeling, and the limitations of idealized systems.
  • One participant questions the flaw in reasoning regarding the infinite momentum transfer from photons reflecting between two spacecraft, suggesting that redshift must occur to conserve energy.
  • Another participant notes that perfect mirrors do not exist, leading to losses from absorption and scattering, which would cause the beam to diminish over time.
  • Concerns are raised about the recoil of the spacecraft when emitting photons, which complicates the momentum transfer analysis.
  • Some participants argue that the absorption and emission of photons do not result in net momentum transfer if considered spherically symmetric, while others counter that the specific geometry of the scenario leads to net momentum transfer.
  • There is a discussion about the complexity of the mathematics involved, with some participants suggesting that conservation laws and de Broglie's relationship could provide a simpler approach, while others emphasize the coupling of electromagnetic fields with ponderable matter as inherently complex.
  • Participants explore the implications of energy transfer, questioning whether emitted photons must have lower energy than absorbed ones due to momentum gain, and discuss the conditions under which light can be confined without frequency shifts.
  • One participant introduces the idea of considering single photons and the potential relevance of solid-state physics and phonons in this context.
Participants express various viewpoints on the mechanics of photon reflection and energy conservation, with no consensus reached on the validity of the initial reasoning or the implications of redshift. Multiple competing views remain regarding the effects of mirror motion, energy transfer, and the mathematical treatment of the problem.
Limitations include the assumption of ideal mirrors, the complexities introduced by moving mirrors, and the unresolved nature of energy transfer in the case of single photons versus macroscopic scenarios.
Sakha
Hello.
Consider 2 spacecraft isolated in space, with a mirror on their back, facing each other. One light pulse is shot between them. The photons reflect off the first one, transferring a momentum off 2p, travels in the opposite directions, reflects off the second spacecraft , giving it 2p again. Repeat forever.
Where is the flaw in this reasoning? I think there has to be some redshift to maintain the Conservation of energy. What equation deals with this redshift?
Science news on Phys.org
Sakha said:
Hello.
I think that conservation of momentum, de Broglie's relationship, and the Doppler effect will all show the same redshift.
Another thing to consider is that there is no such thing as a perfect mirror. There will be losses due to absorption and scattering at every instance of reflection. Within a very short period of time, the beam will vanish.
Sakha said:
Hello.
The first flaw is not taking into account the recoil of the first ship caused by emitting the photon in the first place.
Reflection off a moving mirror has generally been considered in the context of interferometry, specifically gravitational wave sensing. Here's an example:
http://pra.aps.org/abstract/PRA/v51/i3/p2537_1
So to resolve this scenario one needs complex math with Hamiltonians? Isn't there some simple math for it?
I was expecting a very straightforward solution.
You are coupling the momentum of ponderable matter with an electromagnetic field. Why do you think would be simple?
excuse me, but no net momentum results from any photon which is absorbed and then re-emitted, right?
It depends- in this case, the absorption and emission events are not spherically symmetric; there is net momentum transfer.
I don't think it is so complicated. Conservation of momentum and energy together with de Broglie should do it. Obviously, that would be an approximation in the limit that the pulse is very brief.
When you say de Broglie you mean the 'simple' [tex]\lambda = \frac{h}{p}[/tex]?
andy - would that not mean that the energy of the emitted photon must be lower than the absorbed photon, due to the momentum gain?
Isn't this a conservation of energy problem?
The photon has momentum p, so it has energy pc. At most, 100% of the energy can be transferred to the spaceship, so mv^2/2 = pc will give you the maximum velocity.
Yes, and I guess I forgot Planck's relationship between energy and frequency. I always think of both of those together as de Broglie's relationship and neglect to give Planck due credit.
That's a good question. I would naively agree, because E = pc and the transfer of momentum from the photon to the ship would imply a transfer of energy as well. But light can be confined in a high-Q cavity without suffering any frequency shift... Not sure where the relevant difference is between the two.
Edit: Ok, I think I got this part figured out: on resonance, there is no transfer of momentum from the field to the cavity; thus a broadband pulse injected into a high-Q cavity will evolve by transferring the momentum of off-resonant modes to the cavity; the on-resonant components will stably persist over time.
Allowing the mirrors to move means there is no stable resonant mode; field momentum is continuously transferred to the cavity mirrors at some rate equal to the rate of redshifting that occurs from the Doppler effect. Integrating this should give the same result that Vanadium 50 put up (except for a factor of 2; both ships move) in the limit t -> 00.
At least, that's what I came up with a little help from Mr. Noe... :)
That is the result obtained in a limiting case. But consider light reflecting off a mirror that is free to move- in the macroscopic case, it's clear how to proceed: there's radiation pressure, leading to velocity of the mirror, and reflection off a moving mirror is doppler shifted. I found this:
http://www.google.com/url?sa=t&sour...sg=AFQjCNHrV7P1jSzdteHV4ZXJpDyznflcOA&cad=rja
But this again seems to be a macroscopic result: the mirror is set in motion, and light reflects off it. What happens if the field consists of a single photon? Photons are not localized in space, so I'm not sure how to proceed.
Maybe when considering a single photon one would have to consider solid state physics and phonons? (I'm just thinking out loud)
  • · Replies 26 ·
  • · Replies 26 ·
