Why Do Argon Atoms in a Toroidal Box Show Unusually Large Positional Values?
The discussion revolves around the simulation of 100 argon atoms in a toroidal box using the Lennard-Jones potential and the Verlet method for molecular dynamics. Participants are examining issues related to boundary conditions and the calculation of particle positions over time, particularly focusing on unexpectedly large positional values outputted by the simulation.
  • One participant describes their approach to implementing toroidal boundary conditions in Fortran, detailing how they adjust particle positions when they exceed the box dimensions.
  • Another participant expresses confusion about the unexpectedly large positional values (on the order of 10^8) and questions whether their method of updating positions is oversimplified or correct.
  • A later post indicates that the participant has convinced themselves of the validity of their position updates but continues to observe final positions outside the expected range.
  • Participants share snippets of code to illustrate their implementations and seek feedback on potential errors that could lead to the observed discrepancies.
  • There is a mention of randomizing initial positions and velocities once the current issues are resolved.
Participants do not appear to reach a consensus on the cause of the large positional values, as there are ongoing questions about the correctness of the position updating method and the overall implementation of the simulation.
The discussion highlights potential limitations in the code, such as the handling of boundary conditions and the calculation of forces, but these remain unresolved as participants explore different aspects of the problem.
llello
So I'm working on a problem where you have 100 argon atoms in a box that obey the Lennard Jones potential. We're using the Verlet method to calculate the position of each particle at the next time step. The issue I'm having has to do with our boundary conditions. We assume that atoms are on a torus, that way we don't have to worry about binging into the walls.
So my problem arises when I try to calculate their positions at a later time. We're coding in Fortran. So the position of the ith particle is x(i), y(i) and its contained in an LxL box. I go through and calculate what the final positions are and then update those positions so that they're still inside the box. Just an fyi, I also have to keep around the old position for the Verlet method to work. The way I do this updating is as follows:
! adjust for torus
if (x(i) .gt. L) then
a = floor(x(i)/L)
x(i) = x(i) - a*L
xold(i) = xold(i) - a*L
endif
if (x(i) .lt. 0.0) then
a = ceiling(x(i)/L)
x(i) = x(i) + a*L
xold(i) = xold(i) + a*L
endif
if (y(i) .gt. L) then
a = floor(y(i)/L)
y(i) = y(i) - a*L
yold(i) = yold(i) - a*L
endif
if (y(i) .lt. 0.0) then
a = ceiling(y(i)/L)
y(i) = y(i) + a*L
endif
Now the length of my box is just 10.0. But for whatever reason, when I output x, y data for the final time, it gives me extremely large values (order of 10^8 and more). Am I oversimplifying the situation when the particle travels from one side of the box to the other or is this the correct way to update it? If it is correct, how is it I can be getting positions on the order of 10^8?
Many thanks to anyone who takes the time to read this.
-Louis-
Shameless bump of thread.
Final shameless bump before abandoning hope for a reply.
It can take more than 94 minutes for an answer.
So I've convinced myself that my updating of positions is valid. However, I am still receiving final positions outside of the box. This is my entire code. Perhaps someone can find the error. Note, I intend to randomize the starting positions and velocities once I get this to actually work.!
! Program to calculate properties of an argon gas
! using the Verlet method in molecular dynamics.
program assn6no1
implicit none
double precision x(100), y(100), velx(100), vely(100), xold(100), yold(100), energy(10000), velcm(10000)
double precision storex(10000,100), storey(10000,100), time(10000), accelx(100), accely(100)
double precision xnew(100), ynew(100)
double precision L, dt, tempx, tempy, loopx, loopy, loopdistance, cmxtemp, cmytemp, cosine, sine
double precision lineardistance, distance, mass, answer, energytemp, xaccel, yaccel
double precision xdistance, ydistance, p, q, r, s
integer N, i, j, k, timesteps, a
! n = number of argon atoms, L = size of box side (10sigma, sigma=1)
N = 100
L = 10.0
dt = 0.005
mass = 1.0
timesteps = 1000
! initial velocities
do i=1, N
velx(i) = 0.0
vely(i) = 0.0
enddo
! Making the initial positions of 100 argon atoms and x/y at time -dt
do j=1, 10
do i=1, 10
x(i+(j-1)*10) = (i+0.0) - 1.0/2.0
y(j+(i-1)*10) = (i+0.0) - 1.0/2.0
enddo
enddo
! Slightly offsetting each position by 1/10*sigma and calculating x/y(0)
do i=1, N
if (mod(i,2) .eq. 1) then
x(i) = x(i) + 1.0/100.0
y(i) = y(i) + 1.0/100.0
else
x(i) = x(i) - 1.0/100.0
y(i) = y(i) - 1.0/100.0
endif
enddo
do i=1, N
xold(i) = x(i) - velx(i)*dt
yold(i) = y(i) - vely(i)*dt
enddo
! begin calculating motion (time loop)
do k=1, timesteps
! Calculate the acceleration, first initialize
do i=1, N
accelx(i) = 0.0
accely(i) = 0.0
enddo
! first loop is for the ith particle's acceleration
do i=1, N
! calculating a from every other particle
xaccel = 0.0
yaccel = 0.0
tempx = 0.0
tempy = 0.0
do j=1, N
! if statement prevents caclulating acceleration from the same particle
if (i .ne. j) then
cosine = minDist(x(i),x(j))/sqrt( minDist( x(i),x(j) )**2 + minDist( y(i),y(j) )**2 )
sine = minDist(y(i),y(j))/sqrt( minDist( x(i),x(j) )**2 + minDist( y(i),y(j) )**2 )
tempx = xaccel + 1.0/mass*force(x(i),x(j),y(i),y(j))*cosine
tempy = yaccel + 1.0/mass*force(x(i),x(j),y(i),y(j))*sine
xaccel = tempx
yaccel = tempy
endif
enddo
accelx(i) = xaccel
accely(i) = yaccel
enddo
! Calculate the new position of ith particle
do i=1, N
! computing new x/y
xnew(i) = 2.0*x(i) - xold(i) + accelx(i)*dt**2
ynew(i) = 2.0*y(i) - yold(i) + accely(i)*dt**2
! compute velcocity before adjusting for torus
velx(i) = (xnew(i) - xold(i))/(2*dt)
vely(i) = (ynew(i) - yold(i))/(2*dt)
enddo
! adjusting each particle for torus boundary
do i=1, N
if (xnew(i) .gt. L) then
a = floor(xnew(i)/L)
xnew(i) = xnew(i) - a*L
x(i) = x(i) - a*L
endif
if (xnew(i) .lt. 0.0) then
a = ceiling(xnew(i)/L)
x(i) = x(i) - a*L
endif
if (ynew(i) .gt. L) then
a = floor(ynew(i)/L)
ynew(i) = ynew(i) - a*L
y(i) = y(i) - a*L
endif
if (ynew(i) .lt. 0.0) then
a = ceiling(ynew(i)/L)
y(i) = y(i) - a*L
endif
enddo
! updates values
do i=1, N
xold(i) = x(i)
x(i) = xnew(i)
enddo
! store time and velocity data
do i=1, N
time(k) = k*dt
storex(k,i) = velx(i)
storey(k,i) = vely(i)
enddo
enddo
! calculating energy as function of time
do k=1, timesteps
energytemp = 0.0
cmxtemp = 0.0
cmytemp = 0.0
do i=1, N
energytemp = energytemp + 1.0/2.0*(velx(i)**2+vely(i)**2)
cmxtemp = cmxtemp + velx(i)
cmytemp = cmytemp + vely(i)
enddo
energy(k) = energytemp
velcm(k) = sqrt(cmxtemp**2 + cmytemp**2)
enddo!
! Outputting data
open (unit=9, file='positionData.txt', access='append', status='new')
do i=1, N
write(9,*) x(i), y(i)
9 continue
enddo
close(unit=9)
contains
! function to calculate the minimum distance on toroid
double precision function minDist(p,q) result(answer)
double precision, intent(in) :: p
double precision, intent(in) :: q
answer = min( abs(p-q),L-abs(p-q) )
end function minDist!
! function to calculate force between ith/jth particles
double precision function force(p,q,r,t) result(answer)
double precision, intent(in) :: r
double precision, intent(in) :: t
xdistance = minDist(p,q)
ydistance = minDist(r,t)
distance = sqrt(xdistance**2 + ydistance**2)
! if particles are too far, make force zero
if (distance .le. 3.0) then
answer = 24.0*(2.0/(distance**13)-1.0/(distance**7))
else
answer = 0.0
endif
end function force
end program
