Show that a linear map is linearly independent
The discussion revolves around demonstrating the linear independence of a set of vectors generated by a linear map applied to a vector in a vector space. The original poster presents a scenario involving a linear map \( f: V \rightarrow V \) and a vector \( v \) such that \( f^n(v) \neq 0 \) and \( f^{(n+1)}(v) = 0 \).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of the conditions given for \( f^n(v) \) and \( f^{(n+1)}(v) \), questioning how to show that \( f^m(v) \neq 0 \) for \( m < n \) and \( f^p(v) = 0 \) for \( p > n \). They explore applying the linear map to an equation involving the vectors to demonstrate linear independence.
The discussion has progressed with participants offering hints and guidance on how to approach the proof without providing direct solutions. There is an acknowledgment of key steps necessary for the proof, and participants are actively engaging with the concepts involved.
Participants are navigating the constraints of the problem, including the definitions of linear independence and the properties of linear maps, while ensuring they do not provide complete solutions. There is an emphasis on understanding the implications of the mappings and the relationships between the vectors involved.
Mitch_C
Let f:V[tex]\rightarrow[/tex] V be a linear map and let v[tex]\in[/tex]V be such that
f^n(v)[tex]\neq[/tex]0 and f^(n+1)(v)=0. Show that v,f(v),...,f^(n-1)(v) are linearly independent.
I'm really stuck with this one. I know the definition of linear independence and I can see why this might be the case but I don't know how to go about showing this. If anyone could point me in the right direction I should be okay.
thanks
Can you show that for m<n fm(v)≠0 and that for p>n fp(v)=0. I.e. that fn+1 has to be the first mapping that sends v to 0?
If so could you then apply some fb to both sides of this equation: 0 = α0v +α1f(v) + α2f2(v) + ... + αnfn-1(v) that would show α0 = 0 (hint pick the right b). Could you do something similar for α1 = 0, etc?
Ok I think I get you. So how would I go about picking an m and p? Or can I prove that arbitrarily? and for the fb would that be so fb(v) = 1?
Prove it arbitrarily :
The p is pretty easy. Play around with fn+2(v) = f(fn+1(v)). That should show you why p > n goes to zero.
The m<n goes isn't zero is a bit trickier. I don’t want to give away the answer, so let’s consider a nice case where n+1 = 5. So f5(v) = 0, f4(v) ≠ 0, could f3(v) = 0 if f(f3(v)) = f4(v) ≠ 0
Using these properties see what happens if you let b=n and apply it to that equation I gave you.
No, you need to show that the only way that equation can =0 is if all of the αn terms are 0. That’s what it means to be linearly independent. With this method we're going to pick them off one at a time. starting with α0 all the way to αn-1
EXTRA HINT: fn(0) = 0 for any n
Ok that's great thanks a lot! Not only do I now have the question done but I understand it all too! I'm a happy bunny :)
So to make sure I did it right, I took fn the first time to show a0=0 and then fn-1 to show a1=0 and so on until you get fn-n which just gives you the equation back. And because all of the other ais are zero and fn-1(v) is different from zero then the final one an=0. So they're linearly independent and they all lived happily ever after!
Thanks a lot!
exactly! did you get the p and m part? that's a key step.
Yeah I got that part too. I also see why it's a key part :)
  • · Replies 30 ·
  • · Replies 24 ·
