Proving the Vitali Set: A Real Line Challenge
The discussion centers on the proof of properties related to the Vitali set, specifically addressing three key statements regarding Lebesgue measurability. It is established that every Lebesgue measurable subset of a Vitali set is a null set, and that the Vitali set itself is not Lebesgue measurable. Additionally, it is concluded that any set with positive Lebesgue outer measure contains a subset that is not Lebesgue measurable. The construction of the Vitali set involves selecting points from cosets of rational numbers that intersect a set of positive outer measure.
  • Understanding of Lebesgue measure theory
  • Familiarity with cosets and the group of rational numbers
  • Knowledge of null sets in measure theory
  • Experience with constructing sets in real analysis
  • Study the properties of Lebesgue measurable sets in detail
  • Learn about the construction and implications of Vitali sets
  • Explore the concept of outer measure and its applications
  • Investigate the relationship between countability and measure in real analysis
Mathematicians, students of real analysis, and anyone interested in advanced topics in measure theory and set theory.
jem05
Let V a subset of the real line be called a vitali set if V contains precisely one point from each coset of the group of rational numbers. Prove:
1) every lebesgue measurable subset of V is a nullset.
2) V is not lebesgue measurable
3) every set of positive Lebesgue outer measure contains a set that is not lebesgue measurable.
i already did 1 and 2.
i am stuck at 3,
i think i need to consruct a vitali set in the given one which i could do if the set contains an interval,..
but it doesn't need to , all i could know about it is that it is not countable since if it were, then its outermeasure will be zero.
thanks a lot
any help is appreciated
If S is a set of positive Lebesgue outer measure, not every coset of [itex]\mathbb{Q}[/itex] will necessarily intersect S, but uncountably many of them will. Try defining V as follows: from each coset that does intersect S, choose one point from the intersection. Then proceed as you did in 2.
[Edit]: My construction will assure that V is not too small, but you also need to make sure that it isn't too big. But S has outer measure > 0, so there must exist some interval I (say, of length 1) such that [itex]S \cap I[/itex] has outer measure > 0. So replace S by [itex]S \cap I[/itex] and before constructing V.
