Velocity Changes: Understanding Direction and Acceleration in Changing Objects
  • Thread starter Thread starter UrbanXrisis
    Velocity
This discussion clarifies the concepts of velocity and acceleration in changing objects. When an object transitions from -4 m/s to -1 m/s, its velocity becomes less negative, indicating it is moving closer to zero and thus becoming less positive. In the case of an object changing velocity from 2 m/s to -2 m/s, the velocity also becomes less positive as it changes direction, necessitating acceleration. Both scenarios involve acceleration: negative acceleration when slowing down and centripetal acceleration when changing direction.
  • Understanding of basic physics concepts such as velocity and acceleration
  • Familiarity with negative and positive values on a number line
  • Knowledge of centripetal acceleration in circular motion
  • Ability to analyze changes in motion and direction
  • Study the principles of acceleration in physics, focusing on negative and positive acceleration
  • Learn about centripetal acceleration and its applications in circular motion
  • Explore graphical representations of velocity changes using number lines
  • Investigate real-world examples of velocity changes and their implications in various contexts
Students of physics, educators teaching motion concepts, and anyone interested in understanding the dynamics of velocity and acceleration in changing objects.
UrbanXrisis
What if an object is changing from -m4/s to -1m/s. Is the velocity becoming more positive or less positive? Is there acceleration in this?
What if an object is turning around so that it undergoes a change in velocity from 2m/s to -2m/s? Is the velocity becoming more positive or less positive? Is there acceleration while the object is turning?
I assume you mean -4 m/s to - 1 m/s. Well, you figure it out. Draw a number line from -10 to +10 and mark off where -4 and -1 is. When you move from one to the other, which direction do you move, positive or negative.
If the velocity changes, there's acceleration.
Figure this one out the same way.
In both of these scenarios, the velocity is becoming less positive. In the first scenario, the object is slowing down from -4m/s to -1m/s, so its velocity is becoming less negative and therefore closer to 0, making it less positive. In the second scenario, the object is changing direction and its velocity is going from a positive 2m/s to a negative 2m/s, so again, its velocity is becoming less positive.
There is acceleration in both scenarios. In the first scenario, the object is slowing down, which means it is experiencing a negative acceleration. In the second scenario, the object is changing direction, which also requires a change in velocity, and therefore acceleration. This acceleration is known as centripetal acceleration, as it is directed towards the center of the circular motion the object is undergoing while turning.
Overall, it is important to understand that changes in velocity, both in terms of speed and direction, indicate acceleration. Whether the velocity is becoming more positive or less positive depends on the specific scenario and the direction of the change. But regardless, there is always acceleration involved in these types of velocity changes.
  • · Replies 16 ·
