Integration by Partial Fractions
The problem involves evaluating the integral \(\int_0^1 \frac{x-4}{x^2+3x+2} dx\), which requires the use of partial fractions after factoring the denominator.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to factor the denominator and break the fraction into partial fractions, leading to the identification of coefficients A and B. Some participants question the correctness of the final result and whether it aligns with the expectations of an online homework system.
Participants are exploring the validity of the original poster's calculations, with some suggesting that the numerical answer aligns with external sources. There is a recognition of the need to match the answer format expected by the homework system, indicating a productive direction in the discussion.
There is mention of discrepancies between the original poster's answer and the options provided by the online homework system, which may influence the interpretation of the solution.
tangibleLime
[tex]\int_0^1 \! \frac{x-4}{x^2+3x+2} dx[/tex]
Factoring out the denominator...
[tex]x^2+3x+2 = (x+1)(x+2)[/tex]​
Breaking up the main fraction into the separate fractions. Since both are linear, only a single constant is needed on top.
[tex]\frac{A}{x+1}+\frac{B}{x+2}[/tex]​
Fining the coefficients (A and B) by choosing x values that make the other coefficient go to zero.
[tex]x-4 = A(x+2) + B(x+1)[/tex]
[tex]x=-2[/tex]
[tex]-6=B(-1)[/tex]
[tex]6=B[/tex]
[tex]x=-1[/tex]
[tex]-5=A(1)[/tex]
[tex]-5=A[/tex]​
Back in the integral they go. Also, breaking up the main integral into a sum of integrals.
[tex]\int \frac{-5}{x+1}dx + \int \frac{6}{x+2} dx[/tex]
[tex]-5ln(x+1) + 6ln(x+2) + c[/tex]
Now using the fundamental theorem of calculus to find the value.
[tex](-5ln(1+1) + 6ln(1+2))-(-5ln(0+1) + 6ln(0+2))[/tex]​
Result:
[tex]6ln(3)-11ln(2)[/tex]​
Wrong. Aw.
It looks OK to me. Who told you the answer was wrong?
P.S. Wolfram Alpha's answer agrees numerically with yours.
The online homework system... though it gave me multiple options, and none of them were this. I suppose I could try to figure out which is equal, if my work is indeed correct.
http://mikederoche.com/temp/options.png
Got it... equivalent to the second option.
It looks like they really want you to have a [itex]\ln(3/2)[/itex] term for some reason. OK then:
[tex]6 \ln(3) = 6 \ln(2(3/2)) = 6\ln(2) + 6\ln(3/2)[/tex]
  • · Replies 105 ·
13K
