Most effective way to pinch a rubber tube?
  • Thread starter Thread starter WouterWouter
    Rubber Tube
The discussion centers on identifying the most effective method and shape for pinching a rubber tube, focusing on minimizing the force required for effective sealing. Participants explore various approaches and tools suitable for different tube sizes and applications.
  • Wouter seeks advice on the optimal shape for pinching a rubber tube, considering factors like diameter and thickness.
  • Some participants suggest using vise grips as a temporary but effective solution for pinching tubes.
  • One participant proposes using rubber caps for low-pressure situations or silicone sealant for higher pressure, clamped with vise grips until dry.
  • Another suggestion involves using two pieces of wood clamped around the tube, which may be effective but not permanent or aesthetically pleasing.
  • A humorous suggestion involves hiring an elephant to stand on the tube.
  • For soft tubing under 0.5 inches in diameter, disposable blue plastic hemostats are recommended for their speed, price, and effectiveness, with a description of their design aiding in the pinching process.
Participants present multiple competing views and methods for pinching rubber tubes, with no consensus on a single best approach. The discussion remains unresolved regarding the most effective shape and method.
Participants do not specify the conditions under which each method is most effective, such as the type of fluid or pressure involved, which may influence the choice of pinching method.
WouterWouter
Hello,
I am looking for the most effective shape to pinch a rubber tube. The most effective shape requires the least force.
Given a tube of certain diameter/thickness, I want to know whether I should use a flat, curved, knife edged or whatever type of pinch and what thickness it should have.
A reference to a good book or site about this is also welcome!
Wouter
vise grips
Ranger Mike said:
vise grips
:smile: A temporary, but very effective approach. It serves the same purpose as a make-shift vasectomy, but you don't want to even think about the pain...
Wouter (I'm not going to repeat myself), what is the reasoning for capping these things off? Are you trying to maintain internal pressure, or nullify external pressure? My approach has always been to just buy a $.03 rubber cap and snug it down over the tube if it's a low pressure or vacuum situation. For higher pressure, squirt some silicone sealant into the end of the hose and clamp it shut with Vise-Grips until it's dry (give it at least 2 days).
I'm picturing a inner tube for a bicycle tire or something similar...
Try 2 pieces of wood, like 1x2's or 2x4's cut them a couple inches long depending on how wide your tube is and clamp one on each side of the tube with carpentry clamps. Not permanent or pretty but effective.
Hire an elephant to stand on it.:biggrin:
disposable blue plastic hemostats, for soft tubing under .5" diameter, liquid or air. You won't beat the speed, price, and effectiveness.
They have a flat bearing surface, which slopes down to a wider base as a main thickness of each blade part of the hemostat.
  • · Replies 0 ·
