| New Reply |
Parallel and perpendicular vectors |
Share Thread | Thread Tools |
| Oct29-10, 08:29 AM | #1 |
If a mass takes a path down a slope of a parabola. The force downward is its weight. I need to resolve the perpendicular and parallel (to direction of motion) forces.
y=ax^2+bx+c, it has a y intercept of h and a repeated root l. a>0. The mass slides from x=0 to x=l with no friction. [latex] d\vec{r} = \left( \begin{array}{c} 1 \\ 2ax+b \end{array} \right)\text{dx} [/latex] A unit vector in this direction: [latex] \hat{u} = \frac{1}{\sqrt{1+(2ax+b)^2}}\left( \begin{array}{c} 1 \\ 2ax+b \end{array} \right) [/latex] To get the size of the component of the force parallel to the curve: [latex] mg \cos (\theta) = mg\frac{(2ax+b)}{\sqrt{1+(2ax+b)^2}} [/latex] [latex] mg \cos (\theta) \hat{u} = mg\frac{(2ax+b)}{\sqrt{1+(2ax+b)^2}} \frac{1}{\sqrt{1+(2ax+b)^2}}\left( \begin{array}{c} 1 \\ 2ax+b \end{array} \right) = mg \frac{(2ax+b)}{1+(2ax+b)^2}\left( \begin{array}{c} 1 \\ 2ax+b \end{array} \right) [/latex] I don't think this is right |
| Oct29-10, 09:44 AM | #2 |
This can't be right because then
[latex] \int \vec{F}\cdot d\vec{r} = Mg(al^2 + bl) \ne Mgh [/latex] |
| Oct29-10, 04:45 PM | #3 |
Could someone have a look at this
| Oct31-10, 07:07 PM | #4 |
Mentor
Parallel and perpendicular vectorsThe absolute value is not an issue for m, g, and the square-root expression since those are all positive. But what about the 2ax+b term, is that negative or positive? Hints: 1. We are only considering 0<x<l. 2. Express a and b each in terms of h and l, if you have not already done so. |
| New Reply |
| Thread Tools | |
Similar Threads for: Parallel and perpendicular vectors
| find two perpendicular vectors which are perpendicular to another | Calculus | 14 | ||
| Perpendicular Vectors | Calculus & Beyond Homework | 5 | ||
| Given perpendicular vectors A and B, solve A x Y = B for Y | Precalculus Mathematics Homework | 1 | ||
| parallel and perpendicular force | Introductory Physics Homework | 14 | ||
| Perpendicular 3Dimensional Vectors | Introductory Physics Homework | 3 | ||
