| New Reply |
Wire Gauge |
Share Thread |
| Oct29-10, 01:26 PM | #1 |
Wire Gauge
I am going to be pulsing a laser diode at around 2 Watt (room temperature) with a frequency of around 1-10 MHz. Right now I'm planning on using 26 AWG wire. Anyone have any thoughts on whether this is okay? Is the gauge okay? Since it's pulsed I assume I don't have to worry as much about heat dissipation..
I'm not sure of the actual current draw but it should be around 1 - 2 amps. According to this website http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity the max free-air amperage is 2.2 A. I'm kind of skirting the boundary there... Thanks, roeb |
| Oct29-10, 04:20 PM | #2 |
Mentor
| Oct29-10, 04:59 PM | #3 |
Hey, I guess I'm not using that stuff because I'm kind of short on supplies.
So the length of wire itself is less than 10 cm. I'm just soldering a BNC connector to a veroboard and using the AWG 26 wire to connect to diode. The signal pin of the BNC connector itself doesn't look all that much larger than the wire I'm using, but I'm not quite sure if I need to worry about the power that's going through the wire. |
| Oct29-10, 05:04 PM | #4 |
Mentor
Wire Gauge |
| New Reply |
Similar discussions for: Wire Gauge
| Most efficient wire gauge for induction coils | Classical Physics | 3 | ||
| maximum allowable current in a 12-gauge aluminum wire | General Physics | 3 | ||
| wire gauge | Engineering, Comp Sci, & Technology Homework | 7 | ||
| Wire gauge vs. lenght | Electrical Engineering | 2 | ||
| Short duration amperage vs. wire gauge | Electrical Engineering | 6 | ||
