Multiples of natural frequency?
The discussion revolves around the concept of resonance and whether an object can resonate at multiples of its natural frequency. Participants explore the conditions for resonance, particularly in relation to ideal versus non-ideal systems.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions why an object does not resonate with multiples of its natural frequency, suggesting that it may not return to its natural state.
  • Another participant argues that an ideal mass on an ideal spring should resonate at only one frequency, discussing the conditions necessary for resonance and the concept of standing waves.
  • Complexity in resonance modes is highlighted with examples such as a disc of metal and water waves, indicating that different systems may not exhibit harmonic relationships between resonance frequencies.
  • A later reply acknowledges the clarification provided but expresses lingering confusion about the topic.
  • Another participant notes that while the initial ideas apply to a 'perfect' string, the situation becomes more complex in non-ideal conditions.
Participants express differing views on the conditions for resonance, with no consensus reached on whether objects can resonate at multiples of their natural frequency. The discussion remains unresolved regarding the implications of ideal versus non-ideal systems.
Limitations include the dependence on definitions of ideal and non-ideal systems, as well as the complexity of resonance modes in different physical contexts.
LoveKnowledge
Multiples of natural frequency??
Hi all! I am a little confused. Why will an object not resonate with multiples of its natural frequency?
I think due to the reason that through its multiples, it will not return (even if temporarily) to its natural state...am I mistaken??
Thanks in advance for your help!
Can you think of a reason why is should? What are the conditions for resonance?
There is no reason why an 'ideal' mass on an 'ideal' spring should resonate at any more than one frequency.
If you are thinking about a structure which is based on standing waves, then the geometry and the physical details may well not mean that multiple nodes would be sustained at harmonics of the fundamental. This is why they are given the name 'overtones', to avoid confusion.
For this ideal behaviour you need the speed of waves to be independent of the frequency (a special case) and the ends to be ideal reflectors of the waves which are going back and forth.
Consider a disc of metal. The modes of vibration are very complex and you can produce all sorts of resonances over the two dimensional surface. I believe that this may be a good reason why cymbals are made circular so that they produce a very random-like response to being bashed - with no particular audible 'note'.
Take a very familiar case of water waves in a trough. There is no harmonic relationship at all between the frequencies of the different resonance modes. Try it in the bath next time - when the rubber duck ceases to be fun :smile: Try not to get the stopwatch wet, though.
thx for your explanation. it clarifies things up a bit (I understand it 85% now) but just a little confused still.
Your explanation was helpful though. Thanks for your response. :)
For a 'perfect' string, your ideas hold.
But it gets more complicated as soon as you go away from 'ideal'.
:approve:
  • · Replies 30 ·
17K
  • · Replies 40 ·
  • · Replies 52 ·
18K
