Write out the expression for the vertical velocity
The discussion revolves around deriving the expression for vertical velocity from a given position function, z(t) = A sin(vt), which describes the vertical motion of a test particle. The context involves concepts from differential equations and motion in physics.
  • Participants discuss taking the derivative of the position function to find velocity, with some questioning whether additional considerations are necessary due to the nature of the problem. There is also mention of the relationship between the given formula and its origin as a solution to a differential equation.
Participants have provided affirmations regarding the derivative approach, with some expressing uncertainty about the implications of the problem's context. There is an ongoing exploration of whether the simplicity of the derivative approach is sufficient for the problem at hand.
Some participants mention the original equation's role as a general solution for a differential equation, raising questions about the relevance of this context to the derivative process being discussed.
leonne
Given z(t) as above, write out the expression for the vertical velocity
z(t)=Asin(vt)
where z(t) is the vertical position of a test particle, A is the amplitude of its motion,
and t = 0 is the time when the particle is at the midplane
So I just take the the derivative right? I am given position so if i take the derivative of position that give velocity. so is the answer v(t)=Avcos(vt)?
I don't see any problem with that.
cool thxs o one more thing idk if this matters the formula i was given is general solution for a differential equation. idk if that changes anything or if I need to use the original equation or something
The derivative of z(t)=Asin(vt) is Avcos(vt). Nothing can really change that. Whether that solves the original problem is hard to say until you tell what it is.
In class, we showed that the vertical equation of motion for a uniform density disk is
((d^2z)/dt^2) +v^2 z=0
The solution of this differential equation can be written as
z(t) = A sin(vt)
and t = 0 is the time when the particle is at the midplane (z = 0).
Just seems a little to easy that you just take the derivative, but than again i seem to always over complicate the problems lol, but ill just take it like i said before thxs
I'm not sure exactly what physics the situation is trying to derive, but sure, z(t)=A*sin(vt) solves that differential equation, and if z(t) is the vertical displacement then d(z(t))/dt is the vertical velocity. I'm not sure how you could complicate it.
kk thxs i thought maybe you do something different casue its vertical or somthing
  • · Replies 55 ·
