Simple harmonic motion of a body
The discussion revolves around problems related to simple harmonic motion (SHM), including calculations of period, amplitude, and frequency for various scenarios. Participants express frustration with the exercises provided by their teacher and seek assistance in understanding the concepts and solving the problems.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the relationships between acceleration, speed, amplitude, and period in SHM. Some suggest visualizing the motion through sinusoidal graphs and converting between position and velocity representations. Others raise questions about the correctness of formulas used for period and frequency.
Several participants have provided hints and guidance on approaching the problems, including considerations of maximum acceleration and speed. There is an ongoing exploration of different interpretations of the problems, particularly regarding the calculations and relationships among the variables involved.
Participants note the lack of provided answers for the exercises, which contributes to their confusion and frustration. There are also mentions of differing understandings among classmates regarding the problems, indicating a shared struggle with the material.
imbecile
:confused:
My teacher gave us lots of exercise without answer and help i feel so frustrated to complete all those exercise but i can't answer any of them. i search in the book and i can't find anyway suitable way for that question. this question is very simple but i can't get a away to answer it. please help.
1)A body describing simple harmonic motion has a maximum acceleration of 8pie m/s2 and a maximum speed of 1.6 m/s. find the period T and the amplitude R
2)A size is swinging in a horizontal circle 0.8m in diameter, at 30rev/min. A distant light causes a shadow if the stone to be formed on a nearby wall. what is the amplitude of the motion of the shadow? what is the frequency? what is the period?
3)a body executes SHM with an amplitude of 2.00cm and a frequency of 3.00Hz. At t=0s, the displacement is x(0)=0cm and the velocity v(0) is positive.
(a) Obtain analytical expressions for the displacement x(t), the velocity v(t), the acceleration a(t)
(b)evaluate the expressions found in part (a) for t=50ms
anyone who is concern to help me can also add me at msn suding_junix@hotmail.com
your help in solving this questions is highly appreciated thanks...
:blushing:
1) Think about a spring with a mass at the end, which is compressed along a horizontal surface. It is fully compressed then released. Where is the acceleration at its max? Where is its speed at a max? Always write out a list of the information you have, then try to find equations that relate the variables concerned.
2) Hint: the shadow will look and act like a spring.
3) Try thinking about the sinusoidal graphs made by SHM. After that, try converting from one graph (x-t) to the next (v-t). How are amplitude and frequency represented graphically?
Problem #1:
[tex]x(t)=x_{max}\cos \left( \omega t + \phi \right)[/tex]
[tex]\frac{dx}{dt}=v(t)=-\omega x_{max}\sin \left( \omega t + \phi \right) =-v_{max}\sin \left( \omega t + \phi \right)[/tex]
[tex]\frac{dv}{dt}x(t)=-\omega ^2 x_{max}\cos \left( \omega t + \phi \right)=-a_{max}\cos \left( \omega t + \phi \right)[/tex]
So, we have
[tex]\frac{a_{max}}{v_{max}}=\frac{\omega ^2 x_{max}}{\omega x_{max}}=\omega[/tex]
and also
[tex]\omega = 2\pi f=\frac{2\pi}{T}\Longrightarrow T = \frac{\omega}{2\pi}= \frac{1}{2\pi}\cdot \frac{a_{max}}{v_{max}} = \frac{1}{2\pi}\cdot \frac{8\pi \frac{m}{s^2}}{1.6\frac{m}{s}}=2.5 s[/tex] (Period)
[tex]v_{max}=\omega x_{max} \Longleftrightarrow x_{max}=\frac{v_{max}}{\omega}=\frac{1.6 \frac{m}{s}}{\frac{2\pi}{2.5 s}}=\frac{2}{\pi}m[/tex] (Amplitude)
Problem #2
(a) [tex]f=30min^{-1}[/tex]
(b) [tex]T = \frac{1}{f}=\frac{1}{30}min[/tex]
Problem #3
We are given:
[tex]x_{max}=2.00 cm[/tex]
[tex]f=3.00 Hz[/tex]
[tex]t=0[/tex]
[tex]\phi =0[/tex]
[tex]x(0)=0[/tex]
[tex]v(0)>0[/tex]
[tex]\omega = 2\pi f = 2\pi\left( 3.00 Hz \right)[/tex]
So, we find
[tex]x(t)=x_{max}\cos \left( \omega t + \phi \right) = \left( 2.00 cm \right)\cos \left( \omega t + \phi \right)[/tex]
[tex]\frac{dx}{dt}=v(t)=-\omega x_{max}\sin \left( \omega t + \phi \right) =-\left[ 2\pi \left( 3.00 Hz \right) \right] \left( 2.00 cm \right) \sin \left( \omega t + \phi \right)[/tex]
[tex]\frac{dv}{dt}x(t)=-\omega ^2 x_{max}\cos \left( \omega t + \phi \right)=-\left[ 2\pi \left( 3.00 Hz \right) \right]^2 \left( 2.00 cm \right) \cos \left( \omega t + \phi \right)[/tex]
At [tex]t=0[/tex]:
[tex]x(0)=x_{max}= 2.00 cm[/tex]
[tex]v(0)=0[/tex] (not > 0)
[tex]a(0)=-\omega ^2 x_{max}=-\left[ 2\pi \left( 3.00 Hz \right) \right]^2 \left( 2.00 cm \right)=12\pi \frac{m}{s}[/tex]
At [tex]t=50ms=50\times10^{-3}s[/tex]:
[tex]x(50\times10^{-3}s )= \left( 2.00 cm \right)\cos \left[ 2\pi\left( 3.00 Hz \right) \left(50\times10^{-3}s\right) \right]=\frac{\sqrt{-2\left(\sqrt{5}-5\right)}}{2}cm[/tex]
[tex]v(50\times10^{-3}s )=-\left[ 2\pi \left( 3.00 Hz \right) \right] \left( 2.00 cm \right) \sin \left[ 2\pi\left( 3.00 Hz \right)\left(50\times10^{-3}s\right) \right]=-3\left( \sqrt{5}+1 \right)\pi \frac{cm}{s}[/tex]
[tex]a(50\times10^{-3}s )=)=-\left[ 2\pi \left( 3.00 Hz \right) \right]^2 \left( 2.00 cm \right) \cos \left[ 2\pi\left( 3.00 Hz \right)\left(50\times10^{-3}s\right) \right]=-18\sqrt{-2\left(\sqrt{5}-5 \right)}\pi ^2 \frac{cm}{s^2}[/tex]
I was hoping imbecile might arrive at those himself, but ok. Looks like you like Latexing! :)
:redface: i appreciate so so so much for the solutions... i didn't look the answer clearly just go through it cause i am tired now! I will sure look into it after i wake up. so tired and stress up. whole day rushing my school homework, i try to finish up those i manage to do. actually that questions above i think of it for an hour and i get no solutions for that questions. my school teacher teach us the chapter but didn't teach us how to answer questions. i had asked my classmate whether they done the questions anot. the top student in class tells me that she just complete partially and got lots of questions she not sure how to do, while the rest don't know how to do. imagine doing questions without answer?
thank you guys for your help THANKS~~~
I love the use of the term, simple, i don't think any harmonic motion is simple
Hi Tiago,
You had stated that ----> T = \frac{\omega}{2\pi}
I had check... is it supposed to be
-----> T = \frac{2\pi}{\omega} ?
imbecile said:
Hi Tiago,
Period or T is [tex]\frac{2 \pi}{\omega}[/tex]
Frequency is [tex]\frac{\omega}{2 \pi}[/tex]
Sorry for the delay in replying to your message.
Oh... you're right. Sorry about that. I guess I was distracted. :)
Regards.
  • · Replies 51 ·
