Understanding the Evolution of a Gaussian Wave Packet
  • Thread starter Thread starter wany
    Gaussian Wave
The discussion revolves around calculating the wave function \(\Psi(x, t)\) for a Gaussian wave packet, specifically focusing on the amplitude distribution function \(a(k)=C*\alpha*e^{-\alpha^2k^2}/ \sqrt{\pi}\) and its evolution over time. The context is situated within quantum mechanics, particularly in the study of wavefunctions for free particles.
  • Mixed
  • Participants explore the integration over \(k\) and the implications of whether the particle is massive or massless, leading to different forms of the dispersion relation \(w(k)\). There is an attempt to complete the square in the exponent of the integral, with some participants expressing uncertainty about the correct approach and the implications for the wave function's time evolution.
Several participants have provided guidance on completing the square and have noted the importance of correctly identifying the dispersion relation. There is acknowledgment of the evolving nature of the wave packet, with suggestions to consider how its amplitude and width change over time. Some participants have made progress in their calculations and are seeking confirmation of their results.
Participants note that the problem does not specify whether the particle is massive or massless, which affects the calculations. There are also mentions of issues with formatting equations in the forum, which may have impacted the clarity of some posts.
wany
Calculate [itex]\Psi(x, t)[/itex] for the gaussian wave packet according to the amplitude distribution function a(k)=C*[itex]\alpha*e^{-\alpha^2k^2}[/itex]/ [itex]\sqrt{\pi}[/itex]and describe its evolution.
[itex]\Psi(x, t)=\int_{-\infty}^{\infty} a(k)e^{i\{kx-w(k)t\}}dk[/itex]
know that C and [itex]\alpha[/itex] are constants:
So by plugging in for a(k) we get:
[itex]=\frac{c\alpha e^{-iwt}}{\sqrt{\pi}}\int_{-\infty}^{\infty} e^{-\alpha^2k^2}e^{i\{kx-w(k)t\}}dk[/itex]
Now we complete the square: [itex]ikx-\alpha^2k^2=-(\alpha*k-ix/(2\alpha}^2)-x^2/4\alpha^2}[/itex]
let [itex]z=\alpha*k-\frac{ix}{2\alpha}[/itex]
so we have now [itex]\Psi(x, t)=\frac{C*\alpha e^{-iwt}}{\alpha*\sqrt{\pi}}e^{-x^2/4*\alpha^2}\int_{-\infty}^{\infty} e^{-z^2}dz[/itex]
which we know the integral equals [itex]\sqrt{\pi}[/itex]
so by plugging that in and canceling we get [itex]\Psi(x, t)=Ce^{-(iwt+x^2/4*\alpha^2)}[/itex]
First of all I do not know if this is right and second of all how do I describe the evolution.
Thank you in advance.
You should indicate that the integrals are over k. You also didn't specify if we're dealing with a massive particle or not, since
[tex]w(k) = \frac{\hbar^2k^2}{2m}, ~~m>0,[/tex]
[tex]w(k) = kc, ~~m=0.[/tex]
Once you settle that, you will need to complete the square in the exponent of the integral to obtain a true Gaussian integral.
sorry I was in the process of trying to get equations to show properly. The latex function in this forum is not working properly for me for some reason, but yes I completed the square as you can see from my updated.
Also we are not told if its a massive particle or not, but its under the section Wavefunction For A Free Particle.
w(k) is a function of k, you can't just pull out the time dependence. The time-dependence of the wavefunction will be slightly more complicated than just a periodic phase. Presumably you can use the dispersion relation for a massive particle.
ok so plugging in [tex]w(k) = \frac{\hbar^2k^2}{2m}[/tex]
will give us: [itex] =\frac{c\alpha }{\sqrt{\pi}}\int_{-\infty}^{\infty} e^{-\alpha^2k^2}e^{i\{kx-\hbar^2k^2t/(2m)\}}dk[/itex]
So now we need to complete the square of : [itex] ikx-\alpha^2k^2-\hbar^2k^2t/(2m)= ikx-k^2(\alpha^2-\hbar^2t/(2m))[/itex]
I am stuck on how to do this now though since we are stuck with three different terms.
Any help would be appreciated.
The term is still of the form [tex]ak^2 + b k[/tex], you can complete that square easily and then substitute back for a and b.
ok so completing the square I get:
[itex]ikx-\alpha^2k^2-\hbar^2k^2t/(2m)= ikx-k^2(\alpha^2-\hbar^2t/(2m))=-(\sqrt{\alpha^2-\hbar^2t/(2m)}k - \frac{ix}{2\sqrt{\alpha^2-\hbar^2t/(2m)}})^2 - \frac{x^2}{4(\alpha^2-\hbar^2t/(2m))}[/itex]
So we let [itex]z=\sqrt{\alpha^2-\hbar^2t/(2m)}k - \frac{ix}{2\sqrt{\alpha^2-\hbar^2t/(2m)}}[/itex]
Now plugging this back in we get that:
[itex]\Psi(x, t)=\frac{c\alpha }{\sqrt{\pi}}*\frac{1}{\sqrt{\alpha^2-\hbar^2t/(2m)}}*e^{\frac{x^2}{4(\alpha^2-\hbar^2t/(2m))}}\int_{-\infty}^{\infty} e^{-z^2}dz=\frac{c\alpha}{\sqrt{\alpha^2-\hbar^2t/(2m)}}*e^{\frac{x^2}{4(\alpha^2-\hbar^2t/(2m))}}[/itex]
Is this correct? And if so how do I then describe the evolution?
Thank you for your help this far.
I didn't check every step of the math, but it looks reasonable. A Gaussian function is parametrized by it's amplitude and width, try to figure out how these are varying with time. Maybe make a rough sketch for short and long times. A good question to ask is what sets the scale of short and long times.
Ok thank you very much. After some more work, I found the evolution of the wave.
Also for anyone referencing this, I forgot an i and made a mistake on a negative sign:
the completing the square should actually be:
[itex]ikx-\alpha^2k^2-i\hbar^2k^2t/(2m)= ikx-k^2(\alpha^2+i\hbar^2t/(2m))=-(\sqrt{\alpha^2+i\hbar^2t/(2m)}k - \frac{ix}{2\sqrt{\alpha^2+i\hbar^2t/(2m)}})^2 - \frac{x^2}{4(\alpha^2+i\hbar^2t/(2m))}[/itex]
So the rest will change based on this.
Thanks again.
  • · Replies 21 ·
