| New Reply |
Transmittance Function |
Share Thread | Thread Tools |
| Oct31-10, 03:40 PM | #1 |
I have to find the transmittance function T(x,y) of two narrow slits of length L and separated by a distance 2d. 2. Relevant equations ![]() This is what I'm talking about. In my case the x-axis runs in between the slits from the top to bottom (or bottom to top), the slits have a length L and are a distance d from the x-axis. [tex] \mathrm{rect}(\frac{t}{H}) = \begin{cases} 0 & \mbox{if } |t| > \frac{H}{2} \\ 1 & \mbox{if } |t| < \frac{H}{2}. \\ \end{cases} [/tex] 3. The attempt at a solution [tex] T(x,y)=1 \mbox{ if } -\frac{L}{2} \leq x \leq \frac{L}{2} \mbox{ and } y=|d| [/tex] [tex] \mbox{Otherwise } T=0 [/tex] I need to put this into a nicer form, one which will be useful for Fourier transforms. I can reproduce a single slit using step functions, but I'm not sure how to get the two slits at the same time. |
| Oct31-10, 04:56 PM | #2 |
I figured out the case when the slit has some width: [tex]T(x,y)=rect\left(\frac{x}{L}\right) \left[rect\left(\frac{y+d}{t}\right)+rect\left(\frac{y-d}{t}\right)\right][/tex] where t is the thickness. However I'm looking for the case where t is "infinitely narrow"
What I want is to replace [tex]rect\left(\frac{y-d}{t}\right)[/tex] with something like [tex]\delta(y-d)[/tex], however I need it to equal 1 (or something finite) instead of infinity |
| New Reply |
| Thread Tools | |
Similar Threads for: Transmittance Function
| Help us understand spectral transmittance | General Physics | 3 | ||
| Transmittance, Reflectivity and Band gap | Atomic, Solid State, Comp. Physics | 3 | ||
| Light Transmittance | Introductory Physics Homework | 3 | ||
| Relation between Reflectance and transmittance and absorbance | Advanced Physics Homework | 0 | ||
| color transmittance measurement | General Physics | 1 | ||
