Proving an equality using induction
  • Thread starter Thread starter jetpac
    Induction
The discussion revolves around proving an inequality involving a summation for all positive integers n, specifically the expression \(\sum_{i = 1}^n \frac{2i^2 - 1}{i^4} \leq 4 - \frac{2n+1}{n^2}\). Participants are exploring the method of mathematical induction to establish the validity of this inequality.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants attempt to prove the base case for n=1 and then assume the statement holds for n=m to show it for n=m+1. There are discussions about manipulating the left-hand side and right-hand side of the inequality to find a common ground. Some participants express confusion about specific steps and seek clarification on the induction hypothesis.
The discussion is ongoing, with participants providing insights and suggestions on how to proceed with the proof. Some have offered guidance on how to manipulate the terms involved in the inequality, while others are still grappling with the next steps in the induction process.
There are indications of formatting issues in the original posts, and participants have noted the importance of clarity in the mathematical expressions being discussed. Additionally, some participants are working under the constraints of homework rules that may limit the type of assistance they can provide.
jetpac
Proving an inequality using induction
Hey, sorry for any bad formatting, I did my best..
Prove for all positive integers n:
[tex] \sum_{i = 1}^n \frac{2i^2 - 1}{i^4} \leq 4 - ( \frac{2n+1}{n^2} )[/tex]
First prove for n=1:
[tex] \frac{2(1)-1}{1} = 1[/tex]
[tex] 4 - \frac{2+1}{1} = 1 [/tex]
therefore it holds for n = 1
Then assuming the equation holds for any positive integer m, does it hold for n = m+1:
n = m:
[tex] \sum_{i = 1}^m \frac{2i^2 - 1}{i^4} \leq 4 - ( \frac{2m+1}{m^2} )[/tex]
n = m+1:
Subbing m+1 into the RHS gives:
[tex] 4 - \frac{2m + 3}{(m+1)^2}[/tex]
However subbing (i=m+1) into the LHS and adding it to the RHS with (n=m) gives:
[tex] (4 - \frac{2m+1}{m^2} ) + \frac{2(m+1)^2 - 1}{(m+1)^4}<br /> <br /> = 4 - (\frac{2m+1}{m^2} - \frac{2(m+1)^2 - 1}{(m+1)^4})<br /> <br /> = 4 - (\frac{(2m + 1)(m + 1)^4-m^2(2m^2 + 4m + 1)}{m^2(m+1)^4})[/tex]
Next multiply the first equation top and bottom by [tex] m^2(m+1)^2[/tex] gives:
[tex] 4 - \frac{2m + 3}{(m+1)^2} * \frac{m^2(m+1)^2}{m^2(m+1)^2}<br /> = 4 - (\frac{m^2(2m+3)(m+1)^2}{m^2(m+1)^4})[/tex]
So essentially I sub (i = m+1) into the LHS and (n=m) into the RHS and add them (giving the next value in the sequence). Then I compare this to what happens when I just sub (n = m+1) directly into the RHS and isolate exactly what differs between the two methods. The result is that you get [tex]4 - \frac{some number}{m^2(m+1)^4}[/tex] in both cases. The minimum value of {some number} can be found by subbing m=1 into it (since m is positive). So then if {some number} on the LHS is greater than {some number} on the RHS then the original statement also holds for n = m + 1 and therefore all positive integers m?
[tex]\sum[/tex] (2i^2 - 1)/i^4 [tex]\leq[/tex] 4 - ((2n+1) / n^2 )
2(1)-1/1 = 1 (LHS)
4 - (2+1/1) = 1 (RHS)
Then assuming it holds for some pos int m, does it hold for n = m+1:
4 - (2m + 3)/(m+1)^2
However adding (n=m+1) on the LHS to the RHS (n=m):
(4 - (2m+1)/(m^2) ) + (2(m+1)^2 - 1)/(m+1)^4
= 4 - ( 2m+1/m^2 - (2(m+1)^2 - 1)/(m+1)^4 )
So if ( 2m+1/m^2 - (2(m+1)^2 - 1)/(m+1)^4 ) [tex]\geq[/tex] (2m + 3)/(m+1)^2
Then it will hold so put manipulate both sides to have the same denominator:
LHS = ( m^2(2m + 3)(m + 1)^2 ) / (m^2(m + 1)^4)
RHS = ( (2m+1)(m+1)^4 - m^2(2m^2 + 4m + 1) ) / (m^2(m + 1)^4)
Since m >= 1 then subbing m=1 into the following equations:
( (2m+1)(m+1)^4 - m^2(2m^2 + 4m + 1) ) [tex]\geq[/tex] ( m^2(2m + 3)(m + 1)^2 )
gives LHS >= 41, RHS >= 20
And 4 - 41/((m^2(m + 1)^4)) < 4 - 21/((m^2(m + 1)^4))
And so it holds for n = m+1 and by the process of induction all positive integer values of m.
It's difficult for me to follow what you have done, especially since you left off a very important step.
What is the statement that you are assuming to be true when n = m?
Also, here's some help with the LaTeX. Click on this expression to see what I did.
[tex]\sum_{i = 1}^n (2i^2 - 1)/i^4 \leq 4 - ((2n+1) / n^2 )[/tex]
You're right it was pretty messy. I've edited the original post - let me know if that's any easier to understand! Thanks for your help!
That's much easier to follow. I don't have time for a close look now, but will take a look in about an hour, unless someone else jumps in.
Great thanks, if you get a chance at all today or tomorrow I'd appreciate it a lot :)
Anyone able to help me out on this one?
Your induction hypothesis is
[tex]\sum_{i = 1}^m (2i^2 - 1)/i^4 \leq 4 - ((2m+1) / m^2 )[/tex]
You need to use this assumption to show that
[tex]\sum_{i = 1}^{m+1} (2i^2 - 1)/i^4 \leq 4 - ((2(m + 1) +1) / (m + 1)^2 )[/tex]
Start with this:
[tex]\sum_{i = 1}^{m + 1} (2i^2 - 1)/i^4 = \sum_{i = 1}^m (2i^2 - 1)/i^4 + \frac{2(m+1)^2 - 1}{(m + 1)^4}[/tex]
[tex]\leq 4 - \frac{2m + 1}{m^2} + \frac{2(m+1)^2 - 1}{(m + 1)^4}[/tex]
The first two terms above come from the induction hypothesis. Can you work with this to turn it into the right side of the statement you're trying to prove?
Hey Mark, thanks for taking the time to have a look at it. I think I got as far as that calculation above but it was what to do next that I was sort of having difficulty with.
I've tried a few things without much success. The best advice I can give is to work on the last two terms in the last line of what I have in the last line of my previous post. One of the things I tried that might be fruitful is the idea that
4 - (2m + 1)/m^2 <= 4 - (2m + 1)/(m + 1)^2
The idea here is that we're subtracting a smaller quantity from 4 on the right, which means that the overall expression on the right is larger.
  • · Replies 17 ·
