Can Anomalous Dispersion Enhance Resonant Cavities for Solar Cell Applications?
  • Context: Graduate
  • Thread starter Thread starter material
    Dispersion Resonant
The discussion revolves around the potential use of anomalous dispersion in resonant cavities to enhance the efficiency of solar cells. Participants explore theoretical aspects, material requirements, and practical applications related to this concept, including the design of cavities and their interaction with light.
  • Experimental/applied
  • One participant proposes that anomalous dispersion could allow fitting a wide range of frequencies into a resonant cavity.
  • Another participant questions whether a suitable material for the 300nm < λ < 1100nm range exists and if it behaves according to the proposed index of refraction relationship.
  • Concerns are raised about the design of the resonant cavity, specifically regarding light entry and retention due to waveguide modes and total internal reflection.
  • There is speculation about etching tiny rectangular cavities on silicon solar cells to enhance light absorption, but the feasibility and efficiency improvements are uncertain.
  • Participants discuss potential issues such as the size of the cavities, the critical angle for light transmission, and the need for appropriate lens properties.
  • One participant expresses a desire for validation of their ideas and acknowledges their limited expertise in the field.
Participants express various viewpoints and concerns regarding the application of anomalous dispersion in solar cell technology, with no consensus reached on the feasibility or effectiveness of the proposed ideas.
Participants highlight several uncertainties, including the material properties required for effective dispersion, the design parameters of the cavities, and the potential for heating issues. There is also mention of the need for experimental validation, which remains unresolved.
This discussion may be of interest to those involved in solar cell research, materials science, and optical engineering, particularly in the context of enhancing energy efficiency through innovative designs.
material
In anomalously dispersive media, the change in phase velocity with wavelength is negative; that is dv/dλ < 0.
I wanted to ask:
(a) whether you could fit a wide range of frequencies into a resonant cavity by taking advantage of anomalous dispersion
(b) whether a material like this exists for the 300nm < λ < 1100nm range and
(c) whether it exhibits the behaviour of n = λο/λd,
where n = index of refraction, λο = wavelength between 300 and 1100nm, and λd = desired wavelength to design the resonant cavity with λd = 300nm.
(d) whether you could design the resonant cavity so that light goes in but doesn't escape easily because of the waveguide modes and because of total internal reflection characteristics.
I am thinking if you could etch tiny rectangular cavities filled with the right medium on the surface of a silicon solar cell and focus the surrounding light into the cavity, then more of the light will be absorbed by the silicon.
What my maths thinking is:
fo=c/λο, c=300Mm/s
v=fo*λd, v = phase velocity
if λd=300nm,
@ λο=300nm, fo=c/λο=1PHz, v=fo*λd=300Mm/s => n=c/v=1
@ λο=1100nm, fo=c/λο=0.272PHz, v=fo*λd=81.82Mm/s =>n=c/v=3.667
Science news on Phys.org
Interesting application - have you been able to estimate what the theoretical improvement in energy efficiency would be in such a solar cell device?
There are parabolic reflectors for example that do a similar thing - they focus the sun rays whilst tracking the sun as it moves in the sky. I believe that energy enhancements of the order of about 300% are possible in these systems.
The solar cell itself is a very specialised high durability cell that requires a cooling system. (NASA developed one type of these solar cells for some of their satellites and probes)
I'm not sure how much of a difference it would make. There's a lot of issues that I can imagine would affect the outcome. If the cavity is a cube, then the sides of the cube would be 300nm/1.414... = 212nm long for a wavelength at 300nm. I'd need to consider the distance between each cavity so that the walls between each cavity are not so thin that the light goes through the cavity walls. The critical angle of the boundary between the cavity and the next layer of the solar cell must be less than 45 degrees for all frequencies. A micro/nanoscopic lens would have to have the right properties to direct the light within the cavity. I think there would be heating issues. Of course this all depends on whether I understand light dispersion correctly and whether the technology is there at the right price.
I just put the idea out there. I was hoping someone with more knowledge can validate or invalidate the idea.
Can you experimentally validate the application?
(should protect any potentially novel ideas via either secrecy or patent before you publicise them)
No i can't. I'm not working in sciences/engineering, I just have an interest in solar cells and some knowledge from a university education in electronics engineering. I posted on the forum because I was stuck on the unknowns I outlined earlier and I wasn't sure where to turn to next. I just like to search for the sake of learning.
  • · Replies 16 ·
  • · Replies 46 ·
10K
