Electric field inside an infinte slab of linear density charge of thickness d?
The discussion focuses on calculating the electric field inside an infinite slab of charge with a linear charge density defined by ρ(x) = Ax + B, where A and B are positive constants. The key method recommended is to derive the electric field due to an infinitely thin slab of charge and then apply the principle of superposition to integrate the electric field across the entire thickness d. The use of Gauss' Law is suggested as a more efficient approach than directly applying Coulomb's Law for this problem.
  • Understanding of electric fields and charge distributions
  • Familiarity with Gauss' Law and Coulomb's Law
  • Knowledge of superposition principle in electrostatics
  • Basic calculus for integrating electric fields
  • Research the electric field due to an infinitely thin slab of charge
  • Study the application of Gauss' Law in non-uniform charge distributions
  • Learn about the superposition principle in electrostatics
  • Explore integration techniques for calculating electric fields
Students and professionals in physics, particularly those studying electromagnetism, as well as educators looking to explain electric fields in varying charge distributions.
ENgez
An infinite slab of charge with thickness d (from x=0 to x=d) in the x direction has a charge density corrosponding to rho (x) = Ax+B where A and B are positive consants.
Find the electric field at point x1<d
I know i have to find some guassian surface (a cube i guess) which has the same electric field on both planes which are perpandaculer to the x axis. i tried a few but all were wrong. can anyone point me in the right direction?
Sometimes Coulomb's law is more useful than Gauss' Law, but that is a needlessly complicated method, in this case.
Sometimes you can simplify the approach if you take a result of Coulomb's law or Gauss' Law in a simple case, and use that as a basis to solve a more complicated case. In other words, don't try to apply Coulomb's law or Gauss' Law directly for the full problem, but apply either indirectly, via superposition.
I recommend first deriving (or looking up) the electric field due to an infinitely thin slab of charge, and using superposition to integrate the value of electric field for the full slab of thickness d?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elesht.html
If you take this approach, be very careful about the direction of the electric field on each side of an infinitely thin sheet.
thanks, i used superposition. problem solved:).
  • · Replies 36 ·
