Torque required to move a bicycle
In summary, the conversation discusses the amount of torque required to move a bicycle from rest, on an uphill, and to maintain motion. It also mentions the factors that affect torque, such as static friction, rolling losses, and aerodynamic losses. The physics of torque is briefly explained, including its measurement and relationship to force and work. In a vehicle, torque must overcome forces such as propulsion and braking, aerodynamic drag, rolling resistance, and gravity/inertia. The minimum amount of torque required to accelerate a vehicle from 20 km/h to 30 km/h is also mentioned.
ravi.nifty
Hi,
1)I need to find the torque required to move a bicycle from rest, i.e. What is the amount of torque required to be applied at the axis of the wheel of a bicycle, in order to move a 100 kg weight present on it? (Please note that the vechile is at halt and we need to set it into motion, (In short what is the static or starting torque required))
2) What is the amount of torque required to be applied at the axis of the wheel of a bicycle, in order to move a 100 kg weight present on it, When it is needs to move on an uphill of 45 degree ? (Please note that the vechile is at halt and we need to set it into motion), Also answer questions a,b,c of the above question.
3) What is the minimum amount of torque that needs to be applied at the axis of the wheel, to keep it in motion (to avoid coming to halt) when the vechile is already in motion?
4) The vehicle is in motion, and we are trying to accelerate it further, the engine on acceleration will deliver lower torque at higher speeds, Now what is the minimum value to which the torque can be decreased? (what is the minimum amount of torque required to accelerate a vehicle from 20Kmph to 30Kmph. )
In an ideal system, any amount of torque will accellerate any amount of weight. The amount of accelleration will depend on the amount of torque and the amount of weight.
In a real world system you'll have to know the static friction (sometimes called stick-friction) which will determine the startup torque.
And, the rolling losses (tires deflection, bearing and gear losses, etc.) and aerodynamic losses, which will determine the amount of force that counters the torque while the object is in motion. Rolling losses are fairly constant, Aerodynamic losses are square-law.
Can anyone briefly describe the physics of torque to me? I haven't learned about it yet and was just curious.
torque is mesured in Nm (i hope at least, if not google tourque unit converstion). that means that if you push with a force of 1N on a lever of 1m you have a tourque of 1Nm
if you want to push your bike with a force of 1N and you tire radius is 1m you need a tourque of 1Nm on the tire. if you have a pedel that's conected throw a gear of 1/10 you would need 10Nm on the pedal.
easy way to keep track of this is to use the conservation of energy law.
forece * distance = work, not really conservation of engergy but a consquense of it.
to accelerate from 20 to 30 km/h you need to apply at least the torqueneeded to maintain constant speed at 30km/h.
a vehicle movement there are these forces in equilibrium:
- propulsion and braking forces from by engine/cyclist/propeller and brakes
- aerodynamic drag, given by forward speed plus front wind, if any, squared together. And Cx and air density.
- rolling resistance that normally is a fraction of weight. Reasonable rolling resistance is lower than 1%, good is closer to 0,1%.
- gravity/inertia - when the road is not horizontal, inclination will oppose (ascending) or sustain (descending) forward movement. Or acceleration when vehicle changes speed. Horizontal, constant speed means inertial/gravity forces are nil.
Starting on a horizontal road requires overcoming at least rolling resistance. I'm not sure if this is always enough
Wheel torque is given by forward force (or backward braking) multiplied with propulsion/braking wheel radius.
1. What is torque and how does it relate to moving a bicycle?
Torque is the measure of a force that can cause an object to rotate around an axis. In the case of a bicycle, torque is needed to rotate the wheels and move the bike forward.
2. How is torque calculated for a bicycle?
Torque on a bicycle can be calculated by multiplying the force applied to the pedals by the length of the pedal crank arm. The formula for torque is T = F * r, where T is torque, F is force, and r is the lever arm or distance from the point of rotation (in this case, the pedal crank) to the point where the force is applied (in this case, the pedals).
3. What factors affect the torque required to move a bicycle?
The main factors that affect the torque required to move a bicycle are the gear ratio, the weight of the rider and the bike, the terrain, and the speed at which the rider is pedaling. A higher gear ratio, heavier weight, and steeper terrain will require more torque, while a lower gear ratio, lighter weight, and flatter terrain will require less torque.
4. How does torque affect the speed of a bicycle?
The torque applied to the pedals directly affects the speed of a bicycle. The more torque that is applied, the faster the bike will move. However, there is a limit to how much torque a rider can produce, so the speed of a bicycle is also affected by the gear ratio and other external factors.
5. Can the torque required to move a bicycle be reduced?
Yes, the torque required to move a bicycle can be reduced by adjusting the gear ratio to a lower setting, reducing the weight of the rider and the bike, or choosing a flatter terrain. Additionally, keeping the bike well-maintained with properly inflated tires and lubricated chains can also help reduce the torque needed to move the bike.
  • Mechanical Engineering
13K
