Calculating Horsepower for Electric Motor Pressurization
The discussion centers around calculating the horsepower required for an electric motor to pressurize a tank to a specific pressure. Participants explore the relationship between motor horsepower, pressure, and the mechanics of compressors, with a focus on practical applications and experimental setups.
  • Experimental/applied
  • One participant questions how to determine the horsepower needed for an electric motor to pressurize a tank to a specific pressure.
  • Another participant notes that the power rating of a compressor does not indicate the maximum pressure it can achieve, as this depends on various factors.
  • A participant describes a proposed method to create a "poor man's dynamometer" using a motor, pump, and piston to measure pressure at stall to compute horsepower.
  • It is suggested that the maximum pressure a compressor can develop is influenced by the seals and the design of the compressor, rather than just the horsepower rating.
  • One participant proposes measuring RPM alongside pressure to derive horsepower.
  • A later reply emphasizes that horsepower is a measure of energy delivery over time and that measuring pressure at stall does not yield horsepower, as it represents zero RPM.
  • Another participant suggests that to find horsepower, a dynamic measurement involving volume flow rate at a given pressure is necessary.
Participants express differing views on the relationship between horsepower and maximum pressure in compressors, with no consensus reached on the best method to calculate horsepower based on pressure measurements.
Participants highlight limitations in their proposed methods, such as the need for dynamic measurements and the influence of compressor design on maximum pressure. There are unresolved assumptions regarding the ideal conditions for measuring horsepower.
Mike P.
Please forgive what I'm sure is a dumb question, but I'm stumped.
Is there a way to determine the amount of horsepower (from an electric motor for instance) that is req'd to pressurize a tank of a known volume to a specific pressure?
In other words if an electric motor is used to compress air in a tank to the point of motor failure/stall, is there a way to calculate the output horsepower of the motor by using the air pressure present in the tank?
Thanks in advance for your help,
MP
Unfortunately, the power rating of a compressor cannot tell you the maximum pressure it can attain. The power can be used to compare how fast a pump will attain a certain pressure, but the maximum pressure itself depends on many other factors.
Update! Please help
Perhaps i need to clarify.
I'm trying to build a sort of "poor mans dynomometer" to test electric motor output, my idea was to couple the motor to a pump and use the pump to force a fluid (water) into a pipe that would compress a piston into another cylinder that contains air ovbviously the air pressure would increase as the piston is compressed. At some point the motor will stall and a reading of the air pressure in cylinder #2 would be taken and HP computed.
I might be making this much more difficult than i need to so if anyone has other ideas, I'm eager to hear them.
MP
The primary factor affecting max pressure in a compressor is the seals around the compressing piston and in all other parts of the machine.
Assuming that you have perfect pistons and perfect connections that did not leak, the maximum pressure that a compressor can develop will be ddetermined by the maximum force of the power stroke of the "piston" divided by the cross-sectional area of the cylinder the piston goes through (for rotational and diaphragm compressors, there's no "piston" or "cylinder" but they have equivalent parts).
Again, the HP is only a measure of how quickly an engine or motor can do its job. Compressors will have a rating for HP as well as a rating for max pressure. There is no direct relationship between max pressure and HP.
You may be able to measure RPM separately and with pressure, get HP...
Mike P. said:
..my idea was to couple the motor to a pump and use the pump to force a fluid (water) into a pipe that would compress a piston into another cylinder that contains air ovbviously the air pressure would increase as the piston is compressed. At some point the motor will stall and a reading of the air pressure in cylinder #2 would be taken and HP computed.
HP is rate of energy delivery. That means you need to measure not the energy delivered, but the energy delivered divided by the amount of time needed to deliver it. I think you can see that even a low power motor can get your pressure up to any desired level if you use the correct gearing. If you measure the pressure at stall, the only thing you can get is the amount of torque the motor has at zero rpm. Zero rpm also means zero hp. To find hp, you need a dynamic situation. For example, you could measure the amount of volume per unit time (e.g. CFM) that the motor can suck at a given pressure. Power is the volume rate times the pressure.
  • · Replies 30 ·
22K
  • · Replies 33 ·
  • · Replies 169 ·
17K
  • · Replies 67 ·
