Alignment of micro dipoles in magnetic material in external magnetic field.
The discussion revolves around the alignment of micro dipoles in magnetic materials when subjected to an external magnetic field. Participants explore concepts related to diamagnetism, paramagnetism, and the behavior of dipoles formed by orbital and spin electrons. The scope includes theoretical explanations and clarifications of magnetic properties in different materials.
  • Alan asserts that the dipole moment \vec{m} aligns parallel to the external magnetic field \vec{B}, referencing the right-hand rule and the orientation of the dipole's north pole.
  • Alan questions the behavior of diamagnetic materials, noting that they consist of dipoles formed by orbital electrons that oppose the external magnetic field.
  • Another participant cites Lenz's law, suggesting that induced currents in materials with orbiting electrons oppose changes in the magnetic field, leading to diamagnetism.
  • One participant explains that in diamagnetic materials, the magnetizing vector is opposite to the external field, while in paramagnetic materials, the spinning electrons create dipoles that align with the field.
  • Another participant clarifies that atoms with uncoupled electrons can have their magnetic moments align either parallel or anti-parallel to the external field, with parallel alignment being the lower energy state, contributing to paramagnetism.
  • There is mention of nuclear paramagnetism, which is noted to be significantly weaker and difficult to measure.
Participants express various viewpoints on the behavior of diamagnetic and paramagnetic materials, with some agreeing on the basic principles of diamagnetism while others provide differing explanations regarding the alignment of dipoles. The discussion remains unresolved regarding the specifics of how these effects compare to a vacuum and the significance of their relative sizes.
Participants acknowledge the complexity of magnetic properties and the dependence on material composition, but do not resolve the nuances of how these properties interact with external fields or the conditions under which they are measured.
yungman
I just want to verify that the dipole moment [itex]\vec{m}[/itex] in the presence of external magnetic field [itex]\vec{B}[/itex] will line up in the the same direction and parallel with the external field. This is according to the right hand rule that if magnetic field is the direction of the thumb, the current will circulate in the direction of the finger. So the [itex]\vec{m}[/itex] will be in same direction of the external magnetic field.
Also the point of the [itex]\vec{m}[/itex] is the north pole.
But the electron orbital will spin at opposite direction of the current since electron direction is opposite to current.
Can anyone confirm this?
Thanks
Alan
I am also confuse why diamagnetic material which mainly consist of dipoles formed by orbital electrons ( not spin electrons) that will opposed to the external magnetic field instead of in the same direction like in the magnetic materials?
Lenz's law:
An induced current is always in such a direction as to oppose the motion or change causing it
That is why all material containing orbiting electrons are diamagnetic to some extent.
I think I got the answer already. The diamagnetic material mainly have dipoles make of orbital electrons and the magnetizing vector is in opposite direction as the external magnetic field.
In paramagnetic material, the spining electrons is the main source of dipoles and it's magnetization vector is in the same direction as the external magnetic field.
Both source are very week and the permeability is still very very close to in vacuum.
Please tell me whether I am correct.
Thanks
Your first statement about diamagnetism is correct, orbiting electrons create a magnetic field so as to oppose the external field.
If an atom contains uncoupled electrons, their magnetic moments will align either parallel or anti-parallel to the external field. Because laying parallel (in the direction) of the field is the lowest energy configuration, the majority will do this, thus their magnetisation adds to the external field. This is known as paramagnetism.
Paramagnetism and diamagnetism only exist in the presence of external field. The relative sizes of these two effects depends on the substances involved so I couldn't comment on how comparable they are to a vacuum. How close to a vacuum do you need them to be? At what point would you no longer consider it significant? It depends on what you're doing!
There is also nuclear paramagnetism, but this can be thousands of times small than other effects so difficult to measure.
Thanks
Alan
