Blowing Up Capacitors: Safety Tips & Results
  • Thread starter Thread starter kon
    Capacitors
This discussion centers on the dangers and considerations of experimenting with capacitors connected to a 110V wall socket, specifically regarding a 1 farad car audio capacitor. The stored energy in such a capacitor at 110V is calculated to be 6kJ, comparable to the energy released by 1 gram of TNT. Key safety recommendations include using AC-rated capacitors, incorporating a 100-watt light bulb in series to limit current, and adhering to the Two Man Rule for safety when working with high voltages. The consensus emphasizes the necessity of proper electrical training before conducting such experiments.
  • Understanding of capacitor energy storage calculations (E = 0.5CV²)
  • Familiarity with AC-rated capacitors, specifically motor-run capacitors
  • Knowledge of electrical safety protocols, including the Two Man Rule
  • Experience with series circuit configurations and current limiting techniques
  • Research the specifications and applications of AC-rated motor-run capacitors
  • Learn about the Two Man Rule and its importance in electrical safety
  • Study current limiting techniques, including the use of light bulbs in series
  • Explore safe experimentation methods with high-capacity capacitors
Electrical engineers, hobbyists experimenting with capacitors, and anyone interested in safe practices for high-voltage electrical experiments.
kon
hello i am new to this forum so let me start off by saying this was the most likely place to post this (hopefully).
i connected a small capacitor to a 110v wall socket, i want to attempt something similar in retrospect with a 1 farad capacitor (it is a car audio capacitor)
was curious to know how this might turn out as i cannot seem to find one being blown up by overloading the volts on youtube.
i imagine if i were to blow this up, i would need a fuse in the line somewhere butit would probably blow it anyway because it would pull too much current
not the smartest idea, but its fun lol
The energy (E = 0.5CV2) that is stored on a 1F capacitor at 110V is 6kJ. As a comparison, the energy released by the explosion of one gram of TNT is 4kJ. Of course, you knew this already---you wouldn't be so stupid as to insert random electrical components into the wall socket without knowing what you were doing, right?
1) The only capacitors suitable for this application are AC-rated capacitors like "motor-run" capacitors used with electric motors. The largest available at Digikey is 6uF.
2) Always put a 100 watt light bulb in series with any experiment using a wall socket voltage source.
3) Always obey the Two Man Rule when working with electricity over about 15 volts..
4) In my opinion, you do not have enough electricity training to do experiments like this.
Bob S
  • · Replies 29 ·
20K
  • Sticky
  • · Replies 705 ·
24
125K
  • · Replies 101 ·
15K
