Exponential Map of R3: A Closer Look
  • Context: Graduate
  • Thread starter Thread starter enricfemi
    Exponential Map
The discussion revolves around the exponential map in the context of the Lie group (R3, +) and its implications for one-parameter subgroups generated by vector fields. Participants explore the relationship between infinitesimal generators, left-invariant vector fields, and the nature of the exponential map, addressing both theoretical and conceptual aspects.
  • One participant questions whether the one-parameter subgroup generated by an infinitesimal generator X is represented by the exponential map r(t) = exp(Xt) or simply r(t) = Xt.
  • Another participant asserts that the one-parameter subgroup generated by vector X is indeed tX and provides a differential operator representation for it.
  • There is a suggestion that the exponential map can be expressed through power series (Taylor expansion) acting on functions.
  • A later reply clarifies that while the one-parameter subgroup can be exponential, the context is not a matrix group, but can be transformed into one using block matrices.
  • Participants discuss the representation of the vector field and the resulting exponential map, noting that for certain matrices, the exponential simplifies to I + tX.
Participants express differing views on the nature of the one-parameter subgroup and its relation to the exponential map, indicating that multiple competing perspectives remain without a clear consensus.
The discussion includes assumptions about the nature of the vector fields and the mathematical structures involved, which may not be fully resolved or universally accepted among participants.
enricfemi
I don not know whether I was right or not, please give me a hint.
(R3,+) can be considered a Lie group. and its TG in 0 is still R3.
suppose X as a infinitesimal generater, it can give a left-invariant vector field and also an one-parameter subgroup.
but i think, this one-parameter subgroup is not exponential map r(t)=exp(Xt). it should be r(t)=Xt
must a 1-parameter subgroup whose tangent vector at 0 is X, have a unique exponential map?
is there any thing wrong?
One-parameter subgroup generated by vector X is indeed tX.
The generator of this subgroup is the differential operator
[tex]\xi_X=\sum_{i=1}^3X^i\frac{\partial }{\partial x^i}[/tex]
which you can get by differentiating f(x+tX) with respect to t at t=0.
Formally the exponential [tex]\exp(t\xi_x)[/tex] acts on functions by power series (Taylor) expansion.
Thank you, arkajad! So you mean the 1-parameter subgroup generated by vector field can be not exponential map?
It is an exponential. But the point is that what we have is not a matrix group. But, with a standard little trick, we can make it into a matrix group by representing translations as block matrices
[tex]\begin{pmatrix}I&a\\0&1\end{pmatrix}[/tex]
Then it acts on [tex]R^3[/tex] via
[tex]\begin{pmatrix}I&a\\0&1\end{pmatrix}\begin{pmatrix}x\\1\end{pmatrix}=\begin{pmatrix}x+a\\1\end{pmatrix}[/tex]
Now the vector field is represented by
[tex]X=\begin{pmatrix}0&a\\0&0\end{pmatrix}[/tex]
Notice that [tex]X^n=0[/tex] for [tex]n>1[/tex]. Therefore
[tex]\exp(tX)=I+tX[/tex]
and you get what you are looking for.
thanks, that's a brilliant construct. i think i have finally understood it.
