What is the acceleration of the upper block after the string breaks?
  • Thread starter Thread starter eprparadox
    Spring Two masses
The discussion centers on the acceleration of the upper block in a system of two identical blocks connected by a spring when the supporting string breaks. The correct answer to the problem is that the upper block experiences a downward acceleration of 2g immediately after the string breaks. This conclusion is reached by analyzing the forces acting on the upper block, including gravitational force and the force exerted by the spring. The tension in the string is eliminated upon breaking, leading to the equation 2mg = ma, confirming the acceleration of 2g.
  • Understanding of Newton's laws of motion
  • Familiarity with spring force equations (F = -kx)
  • Knowledge of gravitational force (F = mg)
  • Basic principles of dynamics and force analysis
  • Study the dynamics of systems with springs and masses
  • Learn about free body diagrams and force analysis techniques
  • Explore the concept of tension in strings and its role in dynamic systems
  • Investigate the effects of sudden changes in forces on motion
Physics students, educators, and anyone interested in understanding dynamics and force interactions in mechanical systems.
eprparadox
Two identical blocks are connected by a spring. The combination is suspended, at rest, from a string attached to the ceiling, as shown in the figure above (THE FIGURE IS ATTACHED). The string breaks suddenly. Immediately after the string breaks, what is the downward acceleration of the upper block?
(A) 0
(B) g/2
(C) g
(D) Sqrt(2)*g
(E) 2g
F = -kx
F = mg
I'm having trouble labeling accurately the forces on the top block.
For the bottom block, when the system is at rest, there should be a downward force of F = mg and an upward force of F = kx, leaving mg - kx = 0.
Now for the top block, initially, there is an upward tension force, and a downward force of F=mg. How do I describe the force exerted by the the spring + lower block on the upper block? Could I just treat it like the spring isn't there and treat it like a mass of 2m (m for the upper block + m for the lower block) and say 2mg - T = 0. And then when the string is cut, the tension goes away and we get 2mg = m*a, so that a = 2g?
Thanks a lot ahead of time.
Sounds reasonable to me. :approve:
You could present a little more convincing argument by treating the spring as a spring immediately after the string is cut. Thus there are two forces acting on the top block (taking the top block in isolation): gravity (acting on the top block) and the force from the spring. Either way you'll get the same answer though.
Thank you very much.
  • · Replies 52 ·
