How Did Old Magnetic Sensing Torpedoes Detect Submarine Hulls?
  • Thread starter Thread starter Rothiemurchus
    Magnetic
The discussion centers on the mechanisms by which old magnetic sensing torpedoes detected submarine hulls, particularly focusing on the nature of the induced magnetic fields and the operational principles of these torpedoes during WWII.
  • One participant inquires about the specific size of the induced magnetic field strength that the torpedoes were detecting.
  • Another participant argues that WWII torpedoes did not home in on the magnetic field but detonated upon sensing a disturbance caused by a vessel's hull above them.
  • This participant elaborates on the mechanics of detonation, explaining that a blast under the keel would create a snapping motion capable of destroying the vessel.
  • A different participant mentions that late WWII homing torpedoes utilized sound to locate targets, while others followed random paths or circled after a timed delay.
  • One participant reiterates that magnetic sensing torpedoes detected disturbances in the Earth's magnetic field caused by the steel in a vessel's hull, noting how magnetic field lines behave around large ferromagnetic objects.
Participants express differing views on the operational principles of magnetic sensing torpedoes, with no consensus reached regarding the specifics of how these torpedoes detected their targets.
There are unresolved aspects regarding the exact mechanisms of detection and the conditions under which the torpedoes operated, including the definitions of terms like "homing" and the specifics of magnetic field disturbances.
Rothiemurchus
What size of induced magnetic field strength were the torpedoes homing in on and how were they detecting it?
As far as i know, the torpedoes used in WWII were not really homing in on the magnetic field of a vessel.
The were fired and detonated them selfs once under a vessel.
This the "knew" because of the disturbance in the magneticfield becouse of a big chunk of steel above them (being the vessel).
It was so important that the torp's detonated right under the vessel because rather than blowing a hole in the hull, a detonation right under the keel will break the vessel in two because the vessel first is "lifted" out of the water at a point on the keel, putting tremendous stress on the keel, then because of the vacuum (spelled right??) that remains after a blast it is stresses the other way.
A "snapping" motion able of destroying any vessels keel.
homing torpedos in late WW2 used sound to locate targets
some other types ran random paths or circled after a timed delay kicked in
some of both types some times returned to sub that shot them with bad effects
What the old magnetic sensing torpedos detected was the local disturbance in the Earth's magnetic field by all the steel in a surface vessel's hull. Typically the magnetic field lines run nearly parallel to the surface, but as they approch a large ferromagnetic object, the lines of force curve upwards towards it. The torpedos sensed this change in direction and moved toward/detonated beneath a calculated source.
  • · Replies 25 ·
