Probability of measuring specific energy of particle (in a box)
The discussion revolves around a particle-in-a-box problem in quantum mechanics, focusing on the measurement of energy states and probabilities associated with a particle described by a wave function. Participants explore the implications of the potential energy setup and the normalization of the state vector.
  • Participants discuss the calculation of probabilities for energy measurements and the mean energy of the system, questioning how to express these without knowing the complex coefficients. There is also exploration of the implications of state normalization on energy calculations.
Some participants have provided feedback on the original poster's attempts, noting areas of misunderstanding regarding the relationship between coefficients and energy calculations. There is ongoing clarification about the normalization condition and its application in deriving expressions for mean energy.
Participants are working under the constraints of not having specific values for the complex coefficients, which affects their ability to fully resolve the energy calculations. The discussion also highlights the importance of correctly interpreting quantum mechanical principles related to state measurement and normalization.
doorknob
Consider a particle-in-a-box problem, involving a
particle of mass m subject to a potential:
V(x) = +∞ for X≤0
V(x) = 0 for 0<X<L
V(x) = +∞ for X≥L
|ϕn> are the eigenstates of the Hamiltonian H with the corresponding eigenvalues:
En = (n^2)*(hbar^2)*(Pi^2) / 2mL^2
The state of the particle at the instant t = 0 is:
|Ψ(0)> = c1 |ϕ1> + c2 |ϕ2> + c3 |ϕ3> + c4 |ϕ4>
where ci are complex coefficients that satisfy Σ|ci|^2 = 1 (i.e., the state is normalized).
a) When the energy of the particle in the state |Ψ(0)> is measured what is the probability of
finding a value smaller than
3*(hbar^2)*(Pi^2) /mL^2?
b) What is the mean energy <H> and the uncertainty ΔE = [<H^2> − <H>^2] in the energy of the particle in the state |Ψ(0)> ?
c) Give the expression for the state vector |Ψ(t)> at time t. Do the results found in parts (a) and
(b) for t = 0 remain valid at an arbitrary time t? Make sure to show how you arrived at your conclusion.
d) The energy was measured at time t and the result
8*(hbar^2)*(Pi^2) /mL^2?
was found. After this measurement,
what is the state of the system? What is the result if the energy is measured again?
a) the probability of obtaining an eigenvalue corresponding to the eigenstate |Ψ(t)> is:
|<ϕi|Ψ(t)>|^2
However, how do I compare the value to 3*(hbar^2)*(Pi^2) /mL^2? I do not know what the complex coefficients (c1,c2..c4) are.
b) Expectation energy <H> is defined as:
<H> = <Ψ|H|Ψ>
=> <H> = c1*E1<ϕ1|ϕ1> + c2*E2<ϕ2|ϕ2> + c3*E3<ϕ3|ϕ3> + c4*E4<ϕ4|ϕ4>
since normalized, => <ϕi|ϕi> = 1
So <H> = c1*E1 + c2*E2 + c3*E3 +c4*E4
But I do not know what the complex coefficients (c1,c2..c4) are.
c) don't know since have not completed part (a) or (b)
d) I would guess 3nd excited state (I'm assuming n=1 is the ground state)? Since if n=4, then 4^2 = 16.
16*(hbar^2)*(Pi^2) /2mL^2
reduces to 8*(hbar^2)*(Pi^2) /mL^2
After a measurement has been made, the system |Ψ> collapses to one of its eigenstates where it remains forever. If the energy were measured again, it should remain the same value as when you first made the measurement (since the system collapsed).
Any comments, feedback, criticism, would be helpful. I am more interested in the concept and understanding the material. Thank you in advance!
V(x) = +∞ for X≤0
V(x) = 0 for 0<X<L
V(x) = +∞ for X≥L
|<ϕi|Ψ(t)>|^2
I'd expect your answer is supposed to be written in terms of the ci's.
<H> = <Ψ|H|Ψ>
The ci's are complex, so your expression for <H> will generally turn out to be a complex quantity. Does that make sense? You need to be a bit more careful in your calculations.
That's right.
Vela,
Thank you for your response. However, can I use the fact that I know:
to obtain an expression without Ci? For example, when calculating mean energy <H>:
<H> = <Ψ|H|Ψ>
*Note, (my mistake) my initial expression for <H> did not include the squared complex coefficients. It is now resolved to:
=> <H> = (c1^2)*E1<ϕ1|ϕ1> + (c2^2)*E2<ϕ2|ϕ2> + (c3^2)*E3<ϕ3|ϕ3> + (c4^2)*E4<ϕ4|ϕ4>
=> <H> = Σci*Ei*<ϕi|ϕi>
and since <ϕi|ϕi> = 1 we get:
Σ(|ci|^2)*ΣEi
= ΣEi
Is my line of reasoning correct?
doorknob said:
Vela,
<H> = <Ψ|H|Ψ>
That's better but still not quite right. I hope you realize that ci2≠|ci|2.
Σ(|ci|^2)*ΣEi
= ΣEi
These remaining lines are all wrong.
Wow...okay, I guess I'll end up with an expression in terms of Ci's. Also, when you said "these remaining lines are all wrong" did you also mean that I was wrong to make the following assumption:
No, you're correct about the normalization.
  • · Replies 24 ·
  • · Replies 0 ·
