Really simple problem - can't get right answer
  • Thread starter Thread starter justagirl
The problem involves calculating the acceleration of a 50kg block sliding on a horizontal surface with a coefficient of kinetic friction of 0.60, under the influence of a 400 N force applied at a 20° angle. The correct approach requires using the sine function to determine the y-component of the applied force, which affects the net force calculation. The final magnitude of the acceleration is determined to be 3.27 m/s² after correctly accounting for both the x and y components of the forces involved.
  • Understanding of Newton's second law of motion
  • Knowledge of kinetic friction and its coefficient
  • Proficiency in trigonometric functions, specifically sine and cosine
  • Ability to perform vector addition for forces
  • Study the application of Newton's laws in two dimensions
  • Learn about the effects of angle on force components in physics
  • Explore the concept of net force and its role in acceleration calculations
  • Investigate the relationship between friction and motion in different materials
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to forces and motion.
justagirl
Suppose a 50kg block slides along a
horizontal surface where the coefficient of kinetic friction
between the block and the surface is uk = 0.60. A force F =
400 N is now applied, where the
angle of the force above horizontal is 20°.
What is the magnitude of the acceleration of the block?
0.54 m/s2
2.31 m/s2
3.27 m/s2
6.78 m/s2
8.11 m/s2
Here's what i did:
F(x-net) = F(applied) - F(friction) = ma
a = F(applied) - F(friction) / m
= (400)(cos 20) - (50 * 9.8 * 0.6) / 50
= 375 N - 294 N / 50 kg
= 1.67 m/s2
I checked my numbers quite a few times and keep getting
1.67, which is not one of the answer choices. The only thing
I saw was that 3.72 m/s2 is exactly double what I got, but I
can't find an explanation for that.
Thanks!
The answer is 3.27.
You gave the right anwser for the acceleration in the x-direction. Now when you look vertically in the y direction you still have the y-component of the 400 N-force that you forgot (gravity and normal force annihilate each other)
This y-component = 400*sin(20)
Then calculate a_y and you already have a_x =1.67 which is correct.
The magnitude is sqrt((a_x)² + (a_y)²)
marlon
It seems like you have made a small calculation error in your solution. When finding the net force in the x-direction, you should use the sine function instead of the cosine function since the applied force is at an angle of 20° above the horizontal. So, the correct calculation would be:
= (400)(sin 20) - (50 * 9.8 * 0.6) / 50
= 136 N - 294 N / 50 kg
= -3.16 m/s2
Since the direction of the acceleration is opposite to the direction of the applied force, the magnitude of the acceleration would be 3.16 m/s2. This value is closer to the answer choice of 3.27 m/s2, so it is likely the correct answer.
It's always a good idea to double check your calculations and make sure you are using the correct trigonometric function for the given angle. I hope this helps you find the correct answer!
10K
14K
  • · Replies 22 ·
9K
