What Is the Minimum Distance Below a Pivot for a Pendulum String to Stay Taut?
  • Thread starter Thread starter Raziel2701
    Pendulum
The minimum distance below a pivot for a pendulum string to remain taut is determined by the relationship between the tension (T), gravitational force (mg), and the length of the pendulum (L). The correct formulation indicates that the smallest value of d, where T equals zero at the top of the loop, is given by the equation d = (1/2)L((T/mg) + 1). However, the peg must be positioned directly below the pivot, making the top of the loop 2d - L below the pivot. This adjustment is crucial for accurate calculations.
  • Understanding of pendulum mechanics
  • Familiarity with free body diagrams
  • Knowledge of conservation of energy principles
  • Basic algebra for solving equations
  • Study the dynamics of pendulum motion with varying pivot heights
  • Explore the implications of tension in pendulum systems
  • Learn about energy conservation in mechanical systems
  • Investigate the effects of different lengths (L) on pendulum behavior
Students studying physics, particularly those focusing on mechanics, as well as educators looking for clear examples of pendulum dynamics and energy conservation principles.
Raziel2701
A pendulum of length L is initially held horizontal, and is then released. The string runs into a peg a distance d below the pivot. What is the smallest value of d for which the string remains taught at all times?
I did a free body diagram for the mass when it's winding about the peg. I got [tex]T+mg=\frac{mv^2}{L}[/tex]
Then I used conservation of energy:
[tex]\frac{1}{2}mv^2 +mg(L-d)=mgL[/tex]
I solved for v^2 in the force equation and plugged into my conservation of energy equation to get my answer of:
[tex]d=\frac{1}{2}L(\frac{T}{mg} +1)[/tex]
Does that seem ok?
Hi Raziel2701! :smile:
(try using the X2 icon just above the Reply box :wink:)
Your answer should not have T in it …
the smallest value of d for which the string remains taut is that for which T = 0 at the top of the loop. :wink:
And I think you have the wrong set-up …
the peg is d directly below the pivot, so the top of the loop will be 2d - L below the pivot. :wink:
  • · Replies 21 ·
