Why div B = 0 but div H not necessary 0?
  • Context: Graduate
  • Thread starter Thread starter yungman
The discussion revolves around the divergence of magnetic fields, specifically why the divergence of the magnetic field B is zero while the divergence of the magnetic field H is not necessarily zero. Participants reference concepts from electromagnetism, particularly in relation to magnetization (M) and its implications in different materials, including diamagnetic, paramagnetic, and ferromagnetic substances.
  • Some participants note that \nabla \cdot \vec B = 0 does not imply \nabla \cdot \vec H = 0, as indicated in Griffith's textbook.
  • Questions are raised about when \nabla \cdot \vec M is not equal to zero, with examples such as a uniformly magnetized bar magnet where divergence is non-zero at the ends.
  • There is a discussion about whether in all diamagnetic and paramagnetic materials, \vec M is parallel to \vec B_{ext}, and whether linearity and isotropy are required for this relationship.
  • Some participants suggest that ferromagnetic materials may exhibit non-parallel behavior of \vec M to \vec B_{ext} until magnetic domains are aligned.
  • Non-isotropic materials are mentioned, with a participant noting that crystals generally have anisotropic properties and that the relationship between field H and magnetization can be represented by a matrix rather than a scalar.
  • There is a debate about the interpretation of magnetization as equivalent to bound magnetic charges or currents, with references to textbook practices in explaining these concepts.
Participants express various viewpoints regarding the relationship between \vec B, \vec H, and \vec M, with no consensus reached on the implications of magnetization in different materials or the conditions under which divergences are zero or non-zero.
Participants highlight limitations in understanding the divergence of magnetization, particularly in relation to material homogeneity and the spatial dependence of permeability. The discussion also touches on the complexities of representing magnetization in terms of bound charges and currents.
yungman
I am referring specificly to page 273 6.3.2 A Deceptive Parallel in the "Introduction to Electrodynamics" 3rd edition by David Griffith that I am sure most of you have. The book said:
1) [itex]\nabla \cdot \vec B = 0 \hbox { does not imply } \nabla \cdot \vec H = 0[/itex]
2) [itex]\nabla \cdot \vec H = \nabla \cdot \frac{1}{\mu_0} \vec B - \nabla \cdot \vec M = -\nabla \cdot \vec M[/itex].
[itex]\hbox { 3) Only } \nabla \cdot \vec M = 0 \Rightarrow \vec B = \mu_0 \vec H[/itex].
My questions are:
1) When is [itex]\nabla \cdot \vec M \hbox { not equal to } 0[/itex] ?
2) Is it true that all diamagnetic and paramagnetic material, [itex]\vec M \hbox { is parallel to } \vec B_{ext}[/itex] ? Or the material has to be linear and isotropic on top of dia and paramagnetic?
3) Sounds like to me only the ferromagnetic material that [itex]\vec M[/itex] is not parallel to [itex]\vec B_{ext}[/itex] until all domains are lined up with the external magnetic field?
4) what are the example of non-isotropic material?
Consider a bar magnet which is uniformly magnetized parallel to its length. [itex]\nabla \cdot \vec M \ne 0[/itex] at the ends of the magnet.
That is also the part I am confuse.
[tex]\vec M = \frac{\sum^n_{k=1} \vec m_k}{\Delta v} \hbox { and } \vec m = \hat n IS[/tex]
Where n is number of [itex]\vec m[/itex] in [itex]\Delta v[/itex]. and [itex]\hat n[/itex] is unit normal of the oriented surface of [itex]\vec m[/itex] and I is the current generate by the electrol circulating in the dipole. S is the area of the dipole.
In reality, the total flux coming out of the end of the magnet is not straight out forever, it is like magnetic field that bend and circulate back to the end of the magnet which result of
[tex]\nabla \cdot \vec B = 0[/tex].
But we just treat [itex]\vec M[/itex] as vector pointing straight out.
Yes if you treat [itex]\vec M[/itex] just point straight out and never curl back like the magnetic field, then divergence of M is not zero. But this is not magnetic field anymore. If that is your argument, any magnetic material in the presence of external magnetic field [itex]\nabla \cdot \vec H[/itex] will never be zero. When is [itex]\nabla \cdot \vec M[/itex] ever be zero?
M represents the magnetization of a material. The divergence of M could be non-zero when the magnetization is non-uniform. So if we have a problem where the permeabiltiy is homogeneous, then we can always have zero divergence of the magnetization. The trivial example would be a non-magnetic material in free-space but this is trivial because M is zero. But of course if we have materials that have the same permeabiltiy then there is no spatial dependence on the permeability and we then know that the divergence of M must be zero since we can pull out the \mu from Gauss' Law.
In terms of magnetization this just means that the combined strength, number and orientation of the polarizable magnetic dipoles in the material remains constant.
EDIT: M does not curl back for the same reasons that a magnetic field does. M is not directly a magnetic field but it is the polarization of the magnetic moments inside of a material. Disregarding any inherent magnetic properties of a material, normally the microscopic moments are randomly oriented. Only when we apply an external field do some of these moments become polarized. When they are polarized, the applied field rotates the moments or induces an additional magnetic moment. Thus, the net induced moments are aligned along the direction of the applied field. So M only curls if the material is inhomogeneous or if the applied field is curling.
yungman said:
My questions are:
1) When is [itex]\nabla \cdot \vec M \hbox{ not equal to } 0[/itex] ?
4. Crystal in general have anisotropic properties (depending on their symmetries). In general for a non-ferromagnetic crystal, the relation between field H and magnetization is linear but not scalar: susceptibility is not a number but a (symmetric) matrix.
Not sure about your other questions (it has been too long since I studied this stuff). If it helps you can think of [itex]-\nabla \cdot \vec M = \rho_{b}[/itex], as density of bound magnetic charge... so in most cases it is hard to have a piece of volume looking like it has an effective magnetic (monopole) charge. It gets easier at the surface where bound magnetic charge is [itex]\vec M \cdot \hat{\vec n}[/itex] (which is basically the divergence on a 2D boundary) so a possible answer to your first question is: at the surface of a magnetized material where the magnetization field is not parallel to the surface.
[itex] \nabla \cdot \vec B = 0 \hbox { does not imply } \nabla \cdot \vec H = 0 [/itex]
its treating magnetization as though it were the result of dipoles. (pairs of magnetic monopoles)
Yes, your point being...?
Electrons have an intrinsic ("spin") magnetic dipole moment of about [itex]-9.3 \times 10^{-24}[/itex] J/T. No magnetic monopoles are involved.
Guys, cheer up, nobody is talking about free monopoles, I am talking about equivalent bound sources. It is common practice in (good) text-books to point out how magnetization, the volumetric density of magnetic dipoles, is equivalent to
a distribution of magnetic charge of volumetric density [itex]-\nabla \cdot \vec M[/itex] and surface density [itex]\hat{\vec n} \cdot \vec M[/itex],
OR alternatively (in most textbooks)
a distribution of electric currents of volumetric density [itex]\nabla \times \vec M[/itex] and surface current density [itex]\vec M \times \hat{\vec n}[/itex]
(Same is true for polarization and electric fields, one can use magnetic currents as sources)
E.g. take a cylinder with homogeneous magnetization parallel to its z-axis, you can think of the sources of magnetization either as superficial currents along the azimuthal direction or as two distribution of magnetic charge (of opposite sign) on the two cylinder bases.
Better this way?
magnetization[/color], the volumetric density of magnetic dipoles,
is equivalent to [/color]
a distribution of magnetic charge[/color] of volumetric density [itex]-\nabla \cdot \vec M[/itex] and surface density [itex]\hat{\vec n} \cdot \vec M[/itex],​
OR[/color] alternatively (in most textbooks)
a distribution of electric currents[/color]
of volumetric density [itex]-\nabla \times \vec M[/itex] and surface current density [itex]\vec M \times \hat{\vec n}[/itex]​
True, but they are only the same for the external field.
a distribution of electric currents of volumetric density [itex]-\nabla \times \vec M[/itex] and surface current density [itex]\vec M \times \hat{\vec n}[/itex]
Better this way?
You have to forward slash the itex.
Are dia and paramagnetic materials consider homogeneous because [itex]\vec M[/itex] is so weak that
[tex]\vec B = \mu_0 \vec H[/tex]
We only have to concern with ferromagnetic material?
Thx I had not checked the posting
Well, it has been a while but are you sure about that? can you provide an example?
a uniformly magnetized infinitely long bar magnet
The magnetization cannot be defined as a density of magnetic dipoles in general. The problem is that in quantum mechanics, one cannot separate unambiguously one dipole from the other. In older classical electrostatics on the other hand, it was not unusual to define the strength of a dipole via the strength of two monopoles of opposite charge at unit distance.
Nowadays magnetization is simply a restatement of charge conservation as [tex]\nabla j_\mathrm{int}=0[/tex] in magnetostatics, it follows that j _int(the current density due to the atomic currents inside the medium) can be expressed as [tex]-\nabla \times M[/tex], the minus sign being convention. This equation defines M only up to the gradient of a scalar field [tex]\grad \xi[/tex]. So it would be possible to define M in such a way that [tex]\nabla M=0[/tex]. However, in this way not much is won over a description in terms of j_int as the dependence of M on B would be very non-local (that is, of the form [tex]M(r)=\int dr'^3 \chi(r,r')B(r')[/tex], with [tex]\chi(r,r')[/tex] falling off slowly with the distance of r from r') even in cases where a description in terms of well separated atomic dipoles is possible. A description, which on the macroscopic scale is localized, i.e., [tex]M(r)=\chi(r) B(r)[/tex] necessarily means that M(r) has to have a longitudinal component.
Can you elaborate? how is the description in term of surface current failing for the interior field?
1. we are talking about CLASSICAL physics
2. magnetization is defined through a CONTINUOUS distribution of dipoles not a discrete one; an inaccurate model at microscopic scale but still the model
3. elementary dipoles are defined as opposite monopole charges at INFINITESIMAL distance preserving dipole moment in the limit
4. With [tex]\nabla M=0[/tex] I guess you mean div M =0 not grad M =0
5. What is your final point about longitudinal component of M trying to address?
Huh? The surface current gives the correct result.
The dipole distribution reduces to finite charges at the ends of the infinite bar and therefore results in zero field at any finite point. (which is only correct for the exterior field)
I thought it was pretty obvious.
Can anyone answer this?
Also
[tex]\nabla X \vec H = \vec J_{free}[/tex]
I want to confirm that in the boundary condition, even if there is no free current density, H is not zero. It just mean
[tex]\int_C \vec H \cdot d\vec l = 0 \Rightarrow \vec H_{1t} = \vec H_{2t}[/tex]
Where 1t and 2t are for the tangential component of H in top layer and bottom layer.
To 1. I only wanted to say that we are talking about continuous charge and current distributions, whether classical or not I want to leave open. For these, it is not clear how to represent them unambiguously in terms of a dipole density.
To 4. Yes, sorry, I wrote div and chaged it to nabla, that's why the dot is missing.
5. What I really wanted to say is the following: One can write down various forms of the macroscopic Maxwell equations. E.g., instead of introducing polarization and magnetization, one can deal directly with the charge and current distribution of the medium instead. Whatever one uses, the Maxwell equations have to be supplemented by a set of material equations which describe the dependence of the magnetization or of the currents on the magnetic field B. The current is a very non-local function of the magnetic field. The reason for the utility of the magnetization lies in the fact that it can be chosen in such a way as to depend (approximately) only on the local value of the magnetic field. Now by the Helmholtz theorem, every field can be decomposed into it's transverse and longitudinal part, only the latter having a non-vanishing divergence.
In principle, for the Maxwell equations, it would be sufficient to consider only the transverse part of the magnetization, however, this would be a very non-local function of B. So the non-vanishing of div M in the usual formulation is due precisely to the demand for a local relation between M and B.
Let me see if I am following: you are saying
- equivalent current distributions describe fields inside and outside matter
- equivalent charge distributions work only outside
Is that your point?
How does this work out for polarization? Same formal equations but I don't recall many examples using bound magnetic currents in places of bound charges to solve polarization problems...
I guess I will have to go and dig my old books out of storage...
How about my question? Seems like this thread has be hijacked and turn into classical vs quantum physics!
I answered your question completely in post 6
Is that your point?
bound electric[/color] charges are fine since they actually exist.
bound magnetic[/color] charges (monopoles) only work for the external field because they don't actually exist.
I don't understand why you are having so much trouble understanding this.
No, this has nothing to do with quantum mechanics. The divergence of H does not vanish when the relation between B and H is assumed to be local. If [tex]B(r)=\mu(r) H(r)[/tex] and [tex]\nabla \cdot B=0[/tex] then [tex]\nabla\cdot H(r)=-\frac{1}{\mu(r)}H(r)\cdot \nabla \mu(r)[/tex] as the resutl of a simple vector analytical identity, namely [tex]\nabla \cdot a A =(\nabla a)\cdot A+a \nabla\cdot A[/tex] with a a function and A a vector.
How about post #20?
yungman said:
Sorry yungman, apparently the side topic originating from your initial question seems to be annoying you... I will open a new thread and see if we can get this sorted out. Please join in if you feel like it
It's no problem, just don't forget my question!:smile:
Might that not be the crux of the matter?
I think indeed that in strict classical physics: [itex]\hbox \nabla \cdot \vec M = 0[/itex]
To add magnetisation in classical electrodynamics, you need a additional empirical model.
Based on classical charges and their motions, you can't get any magnetisation.
I don't know what you mean unless you are saying that classically electrons should stop circling the nucleus and shouldn't have spin.http://en.wikipedia.org/wiki/Magnetization
The origin of the magnetic moments responsible for magnetization can be either microscopic electric currents resulting from the motion of electrons in atoms, or the spin of the electrons or the nuclei
