Find force with mass and variable position
The discussion focuses on calculating the work done by a force acting on a 2.80 kg particle, with its position defined by the equation x = (3.0 m/s)t - (4.0 m/s²)t² + (1.0 m/s³)t³. The initial attempt to calculate work using W = ∫F(t) dt led to confusion, as the integral represents impulse, not work. The correct approach is to apply the work-energy principle, W = K_f - K_i, which correctly yields the work done as 493 J, aligning with the textbook answer.
  • Understanding of Newton's second law (F = ma)
  • Familiarity with calculus, specifically integration
  • Knowledge of the work-energy theorem
  • Ability to perform dimensional analysis
  • Study the work-energy theorem in detail
  • Learn about impulse and momentum concepts
  • Practice dimensional analysis techniques
  • Explore advanced integration techniques in physics
Students studying physics, particularly those focusing on mechanics and the work-energy principle, as well as educators looking for problem-solving strategies in force and motion scenarios.
zrbecker
A force acts on a 2.80 kg particle in such a way that the position of the particle as a function of time is given by x = (3.0 m/s)t - (4.0 m/s^2)t^2 + (1.0 m/s^3)t^3. Find the work done by the force during the first 4.0s.
[tex]W = \int_{t_i}^{t_f} F(t) dt[/tex]
[tex]F = ma[/tex]
[tex]W = \int_0^4 F(t) dt = \int_0^4 ma(t) dt = mv(4) - mv(0) = m(x'(4) - x'(0))[/tex]
[tex]x'(t) = 3 - 8t + 3t^2[/tex]
[tex]x'(4) = 19[/tex]
[tex]x'(0) = 3[/tex]
[tex]W = 2.8 * 16 = 44.8J[/tex]
The book is saying it is 493J
The integral of force with respect to time is not the work done by a force; it is the impulse of that force. The easiest way to convince yourself that there is a problem with your equations is by dimensional analysis. In your final equation, you have 2.8 kg * 16 m/s or 44.8 N*s. A Joule is a N*m.
So the first step is to double check your definition of work.
Otherwise, I think that you have an excellent start on the problem.
Ah thanks. Yeah my bad it is suppose to be the integral with respect to position.
I see why that doesn't work now.
I found the better way to do this was to use
W = K_f - K_i
and that got me to where I wanted to go. Thanks for the help.
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 17 ·
