Finding the Metric in Stereographic Projection
The discussion revolves around finding the metric in X,Y coordinates resulting from the stereographic projection from the 2-sphere to the 2-dimensional plane. Participants explore various approaches, including the use of spherical coordinates and transformations between coordinate systems.
  • One participant inquires about the method to find the metric in X,Y coordinates after applying stereographic projection.
  • Another suggests starting with spherical coordinates and mentions a simplification involving the sine and cosine functions.
  • A participant proposes that the Riemannian metric is relevant and discusses using the stereographic projection to pull back a 2-form.
  • One participant describes their parametrization of the sphere and the transformation to the XY plane, leading to a proposed expression for the metric.
  • Another participant provides a simplification for the sine over cosine expression, clarifying its relation to cotangent.
  • There is a suggestion to change one of the coordinates based on the geometrical definition of cotangent, which may simplify the problem.
  • A participant reflects on their earlier misunderstanding and acknowledges the connection between cotangent and stereographic projection.
Participants express various methods and approaches to the problem, but there is no consensus on a single correct method or outcome. The discussion remains exploratory with multiple perspectives presented.
Some participants note the necessity of using spherical coordinates to parametrize a 2-dimensional surface, highlighting the complexity of working with three-dimensional coordinates under constraints.
mnb96
Hello,
if we consider the stereographic projection [itex]\mathcal{S}^2\rightarrow \mathbb{R}^2[/itex] given in the form:
[tex](X,Y) = \left( \frac{x}{1-z} , \frac{y}{1-z} \right)[/tex]
how can I find the metric in X,Y coordinates?
-- Should I first express the projection in spherical coordinates, then find the inverse projection [itex]\mathbb{R}^2\rightarrow \mathcal{S}^2[/itex]?
hello mnb96! :smile:
start with spherical coordinates, and use a simplification for sin/(1 - cos) :wink:
I think they may be referring to the Riemannian metric. If this is so, then
the R-metric is a 2-form, so you just need to use the stereo projection
to pullback a 2-form.
oK, thanks to you both.
I tried the following:
I parametrized the S^2 sphere with coordinates [itex](\theta,\phi)[/itex], then I wrote down the transformation from the S^2 sphere (with spherical coordinates) to the XY plane (with polar coordinates):
[tex]R = \frac{\sin\theta}{1-\cos\theta}[/tex]
[tex]\alpha = \phi[/tex]
Then I simply used the polar->cartesian transformation to obtain:
[tex]X(\theta,\phi) = \frac{\sin\theta \cos\phi}{1-\cos\theta}[/tex]
[tex]Y(\theta,\phi) = \frac{\sin\theta \sin\phi}{1-\cos\theta}[/tex]
At this point I was ready to compute the metric as:
[tex]ds^2 = dX^2 + dY^2 = \frac{1}{(1-\cos\theta)^2} \left( d\theta^2 + \sin^2 \theta \cdot d\phi^2 \right)[/tex]
Was this correct?
@tiny-tim: I don't know what you meant by simplification for sin(x)/(1-cos(x))
sinx/(1 - cosx) = 2sin(x/2)cos(x/2) / 2sin2(x/2) = cot(x/2) :wink:
tiny-tim said:
sinx/(1 - cosx) = 2sin(x/2)cos(x/2)/2sin2(x/2) = cot(x/2) :wink:
Ah, you meant that! :redface:
Thanks!
-- However, the end of the story was that we were forced to use spherical coordinates because we needed to parametrize a 2-dimensional surface with two parameters, and not three-parameters x,y,z plus a quadratic constraint.
(have a theta: θ and a phi: φ :wink:)
i think you're missing the obvious …
using coordinates θ and φ, you already have X = cot(θ/2)cosφ, Y = cot(θ/2)sinφ …
so change one of the coordinates again! :smile:
Uhm...ah yes! maybe I got what you were trying to tell me :)
Darn, you were just suggesting me to use the geometrical definition of 'cotangent'. This way everything becomes almost trivial.
Actually now that I think about it, the cotangent operator itself does a stereographic projection of the 1-sphere onto the real line. Stupid me.
I think I missed it because I tried to directly work on the stereographic projection for the n-sphere.
he he! :biggrin:
  • · Replies 39 ·
  • · Replies 0 ·
  • · Replies 0 ·
