Multi-Cycle Processor Implementation in Verilog?
  • Thread starter Thread starter pags920
    Processor
The discussion focuses on the implementation of a multi-cycle processor in Verilog for the MIPS instruction set, specifically addressing an issue with executing an instruction stored in Memory[6]. The user is utilizing a Verilog module named CPU, which includes various opcodes such as BNE, J, JAL, and others. A key insight from the conversation indicates that the user is not checking the opcode for the last instruction in the program, which is critical for proper execution. The problem lies in the transition between states 3 and 4 in the CPU's control logic.
  • Understanding of MIPS instruction set architecture
  • Familiarity with Verilog hardware description language
  • Knowledge of multi-cycle processor design concepts
  • Experience with state machine implementation in digital circuits
  • Review Verilog state machine design patterns for multi-cycle processors
  • Learn about opcode handling in MIPS architecture
  • Investigate debugging techniques for Verilog simulations
  • Explore the implementation of control logic in multi-cycle processors
Students and engineers involved in digital design, particularly those working on MIPS architecture and Verilog implementations, will benefit from this discussion. It is also relevant for anyone troubleshooting multi-cycle processor designs.
pags920
I am trying to design a multi-cycle processor in Verilog for the MIPS instruction set. However, I cannot get one of my instructions that I stored in memory to execute. This program is a continuation of a lab assignment that was given to my class.
The instruction that I am trying to execute is in Memory[6]. If anyone experienced in MIPS and Verilog can see where the problem is, that would be so helpful.
Code:
module cpu_tb;
wire[31:0] PC, IR, ALUOut, MDR, A, B, reg7;
reg clock;
CPU cpu1 (clock,PC, IR, ALUOut, MDR, A, B, reg7);// Instantiate CPU module
initial
begin
clock = 0;
repeat (300)
begin
#10 clock = ~clock; //alternate clock signal
end
end
initial #5000 $finish; //end simulation after 110 nano second
endmodule
module CPU (clock,PC, IR, ALUOut, MDR, A, B, reg7);
        parameter BNE = 6'b000001; //opcode for BNE
        parameter J = 6'b000010; //opcode for J
        parameter JAL = 6'b000011; //opcode for JAL
        parameter BEQ = 6'b000100; //opcode for BEQ
        parameter ADDI = 6'b001000; //opcode for ADDI
        parameter SLTI = 6'b001010; //opcode for SLTI
        parameter ANDI = 6'b001100; //opcode for ANDI
        parameter ORI = 6'b001101; //opcode for ORI
        parameter SINC = 6'b011111; //opcode for SINC
        parameter LW = 6'b100011; //opcode for LW
        parameter SB = 6'b101000; //opcode for SB
        parameter SW = 6'b101011; //opcode for SW
        parameter LI = 6'b111111; //opcode for LI
        input clock;  //the clock is an external input
        //Make these datapath registers available outside the module in order to do the testing
        output PC, IR, ALUOut, MDR, A, B;
        reg[31:0] PC, IR, ALUOut, MDR, A, B;
        output [31:0] reg7; //output reg 7 for testing
        // The architecturally visible registers and scratch registers for implementation
        reg [31:0] Regs[0:31], Memory [0:1023];
        assign reg7 = Regs[7]; //output reg 7
        reg [2:0] state; // processor state
        wire [5:0] opcode; //use to get opcode easily
        wire [31:0] SignExtend, PCOffset; //used to get sign extended offset field
        assign opcode = IR[31:26]; //opcode is upper 6 bits
                //sign extension of lower 16-bits of instruction
        assign SignExtend = {{16{IR[15]}},IR[15:0]};
        assign PCOffset = SignExtend << 2; //PC offset is shifted
        assign ZeroExtend = {{16{IR[1'b0]}}, IR[15:0]};
        assign BranchAddr = {{14{IR[15]}}, IR[15:0], 2'b0};
        assign JumpAddr = {{PC+{IR[31:28]}}, IR[25:0], 2'b0};
        //Load a test program and data into memory
        initial
        begin
                Memory[2] = 32'h8c070078; //lw instruction
                Memory[3] = 32'hac0700f8; //sw instruction
                Memory[4] = 32'b111111_01000_00000_0000000000000001; //li instruction
                Memory[5] = 32'b000001_01000_01000_0000000000000001; //bne instruction
                Memory[6] = 32'b000000_01000_01000_00000_00000_010100; //add
                Memory[30] = 9;
        end
        // set the PC to 8 and start the control in state 1 to start fetch instructions from Memory[2] (byte 8)
        initial
        begin
                PC = 8;
                state = 1;
        end
        always @(posedge clock) begin
        //make R0 0
        //short-cut way to make sure R0 is always 0
        Regs[0] = 0;
        case (state) //action depends on the state
        1: begin     //first step: fetch the instruction, increment PC, go to next state
                IR <= Memory[PC>>2]; //changed
                PC <= PC + 4;        //changed
                state = 2; //next state
                end
        2: begin     //second step: Instruction decode, register fetch, also compute branch address
                A = Regs[IR[25:21]];
                B = Regs[IR[20:16]];
                state= 3;
                ALUOut <= PC + PCOffset;         // compute PC-relative branch target
                end
        3: begin     //third step:  Load/Store execution, ALU execution, Branch completion
                state = 4; // default next state
                if ((opcode==LW) |(opcode==SW)) ALUOut <= A + SignExtend; //compute effective address
                else if (opcode==6'b0) case (IR[5:0]) //case for the various R-type instructions
                                        0: ALUOut = B << IR[10:6]; //sll operation
				                              	2: ALUOut = B >> IR[10:6]; //srl operation
				                               	8: PC = A; //jr operation
				                               	20: ALUOut = A + B; //add operation
				                              	22: ALUOut = A - B; //sub operation
			                              		24: ALUOut = A & B; //and operation
			                              		25: ALUOut = A | B; //or operation
			                               		27: ALUOut = ~(A | B); //nor operation
			                              		28: ALUOut = (A < B) ? 1:0; //slt operation
                                        default: ALUOut = A; //other R-type operations
                                        endcase
                else if (opcode==6'b111111) begin Regs[IR[25:21]]<= SignExtend; state = 1; end //ALU operation for LI instruction
                else if (opcode==6'b001000) begin Regs[IR[20:16]]<= SignExtend; ALUOut = A + SignExtend; state = 4; end //ALU operation for ADDI instruction
                else if (opcode==6'b001100) begin Regs[IR[20:16]]<= ZeroExtend; ALUOut = A & ZeroExtend; state = 4; end //ALU operation for ANDI instruction
                else if (opcode==6'b001101) begin Regs[IR[20:16]]<= ZeroExtend; ALUOut = A | ZeroExtend; state = 4; end //ALU operation for ORI instruction
                else if (opcode==6'b001010) begin Regs[IR[20:16]]<= SignExtend; ALUOut = (A < SignExtend) ? 1:0; state = 4; end //ALU operation for SLTI instruction
                else if (opcode==6'b000001) if(A!=B) begin PC = ALUOut; state = 1; end //ALU instruction for BNE instruction
                else if (opcode==6'b000100) if(A==B) begin PC = ALUOut; state = 1; end //ALU instruction for BEQ instruction
                else state = 1;
                else ; // other opcodes or exception for undefined instruction would go here
                end
        4: begin
                if (opcode==6'b0) begin //ALU Operation
                        Regs[IR[15:11]] <= ALUOut; // write the result
                        state = 1;
                end //R-type finishes
                else if (opcode == LW) begin // load instruction
                        MDR <= Memory[ALUOut>>2]; // read the memory
                        state = 5; // next state
                end
                else if (opcode == SW) begin
                        Memory[ALUOut>>2] <= B; // write the memory
                        state = 1; // return to state 1
                end //store finishes
                else if (opcode == LI) begin //load immediate
                        Regs[IR[25:21]] <= ALUOut; //write to IR
                        state = 1; //return to state 1
                end
                else if (opcode == ADDI) begin //add immediate
                        Regs[IR[20:16]] <= ALUOut;  //write to IR
                end
            		else if (opcode == ANDI) begin //and immediate
	             	end
                else if (opcode == BEQ) begin //branch if equal
                        if (ALUOut != 0)
                        else
                        PC <= IR[15:0] + SignExtend; //write to program counter, branch address
                end
                else if (opcode == ORI) begin //or immediate
                        Regs[IR[20:16]] <= A | ZeroExtend; //write to IR
                end
                else if (opcode == SLTI) begin //set if less than immediate
                end
                else if (opcode == SB) begin //store byte
                        Memory[A + {SignExtend[7:0]}] <= B; //write to memory
                        state = 1; //reurn to state 1
                end
                else if (opcode == J) begin //jump
                        PC <= JumpAddr; //write to program counter, jump address
                end
                else if (opcode == JAL) begin //jump and link
                        IR[31] <= PC + 8; //write to the last bit in IR
                        PC <= JumpAddr; // write to program counter, jump address
                        state = 1;
                end
                else if (opcode == SINC) begin //sinc
                        MDR <= Memory[ALUOut>>2]; //write to memory
                        Regs[IR[20:16]] <= A + SignExtend; //write to IR
                        state = 5; //proceed to state 5
                end
                else if (opcode == BNE) begin //branch if not equal
                        if (ALUOut == 0)
                        else
                end
        end
        5: begin     //LW is the only instruction still in execution
                Regs[IR[20:16]] = MDR;                 // write the MDR to the register
                state = 1;
                end //complete a LW instruction
        endcase
           end
endmodule
Okay, I was told that I am not checking for the opcode in my last instruction anywhere in program. However, it wasn't explicitly clear as to where I would check it at. I know that it has to be checked somewhere between states 3 and 4.
