Prove that an even degree poly has either a absolute max or min.
The discussion revolves around proving that an even degree polynomial has either an absolute maximum or minimum. Participants explore the properties of polynomials, particularly their behavior at infinity, and the implications of continuity and boundedness in relation to extreme values.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the limits of polynomials as x approaches infinity and the implications for boundedness. There are attempts to clarify the role of the polynomial's degree and continuity in the proof. Questions arise about the definitions of sets used in the proof and their boundedness.
The discussion is active, with participants providing insights and alternative perspectives on the proof. Some express satisfaction with the reasoning presented, while others seek simpler or more elegant proofs. There is an ongoing examination of the relationships between different mathematical theorems and concepts, such as the Extreme Value Theorem and Bolzano-Weierstrass.
Participants note the importance of assumptions regarding the leading coefficient and the behavior of the polynomial at both ends of the x-axis. There is a focus on the implications of these assumptions for the sets defined in the proof.
╔(σ_σ)╝
My brain hasn't been working lately so if you see something weird in my proof pardon me and advice me against it.
So the problem states:
Show that an even degree polynomial has either an absolute max or min.
Let f(x) be an even degree poly.
Without loss of generality suppose, [itex]\displaystyle\lim_{x \to\infty} f(x) = \infty[/itex].It is obvious that f(x) is not bounded above, so we have no absolute max in this case.
Let [itex]S = [tex]\left\{x : f(x) \leq 0\right\}[/tex]<br /> <br /> S is bounded below since f(x) does not go to [itex]-\infty[/itex].<br /> <br /> Let [itex]A = \left\{f(x) :x \in S\right\}[/itex]<br /> <br /> A is bouded below since f(x) does not go to [itex]-\infty[/itex].<br /> <br /> LEt [itex]\beta = infA[/itex].<br /> <br /> For every n there exist [itex]x_n \in [a,b][/itex] such that [itex]\beta \leq f(x_n) < B + \frac{1}{n}[/itex]<br /> <br /> (Note a and b exist because of the f(x) does not go to [itex]-\infty[/itex] and f(x) goes to [itex]\infty[/itex] respectively. )<br /> <br /> [tex]f(x_n) \rightarrow \beta[/tex]<br /> <br /> There exist [itex]x_{n_k} \rightarrow x[/tex] since [itex]x_n[/tex] is bounded.<br /> <br /> Also [itex]x \in [a,b] [/tex]By uniqueness of limits and continuity [itex]f(x_{n_k}) \rightarrow f(x) = \beta[/itex]<br /> <br /> For the case where f(x) > 0 for all x and f(x) still goes to infinity as x goes to infinity I used the set [itex]S = \left\{x : f(x) \leq f(0)= a_0 \right\}[/itex] then the proof is analogous.<br /> <br /> Also the proof is the same when [itex]\displaystyle\lim_{x \to\infty} f(x) = -\infty[/itex] except we find a max instead.[/itex][/itex][/itex][/itex]
All seems well, save for one little thing. Where did you use that the polynomial has even degree?
I used it in my limits as x goes to +/- infinity. I used the property that the limits are the same as x goes both ways.
Yes. It seems your proof is completely correct then...
Thanks. Do you know of a better or easier proof?
Mine seems like overkill. It uses too many things.
I used Bolzano Weierstrass, completeness (sup and inf), and at least 2 limit theorems. :-(
Really you just need that f is continuous and lim f(x)->infinity as |x|->infinity. That means there is an M such that for all x>M f(x)>f(0). And there is an m such that for all x<m f(x)>f(0). There's nothing special about f(0), I just picked 0. Now you need the extreme value theorem on [m,M]. I don't think that's overkill. It's what you need.
That is pretty much what I did, in a sence, but I forgot about the extreme value theorem.
Your proof seems a lot easier to formulate; cool!
So from what I see you basically get rid of the big intevals where f(x) is big; form a closed interval and apply EVT. That's cool. You also use the fact that f(x) is bounded on [m,M]. Am i right?
I guess my proof is not too much stuff then (apart from the two sets :-P). I guess this question calls for a lot of things. I just thought there might be a really clever proof out there.
What is the behavior of the polynomial as [itex]x \rightarrow \pm \infty[/itex]?
It's infinity. Why do you ask ?
What is the sign of the infinity on each side?
Positive.
I already know this.
I don't see the point of these questions. Can you be more direct if you have an alternative solution?
I already solved the problem afterall XD.
Edit
positive; assuming on is the leading coefficient is positive.
So from what I see you basically get rid of the big intevals where f(x) is big; form a closed interval and apply EVT. That's cool. You are still using the fact that f(x) is bounded on [m,M]. Am i right?
I'm really just doing the same thing you did with more convenient names. EVT is a form of Bolzano-Weierstrass. I don't need to show f(x) is bounded on [m,M]. Polynomials are continuous. Continuous functions are bounded on closed intervals. That BW or EVT, whatever you want to call it.
╔(σ_σ)╝ said:
Let [itex]S = \left\{x : f(x) \leq 0\right\}[/itex]
S is bounded below since f(x) does not go to [itex]\mathbf{-\infty}[/itex].
Why?
EDIT:
example:
[tex] f(x) = x^{2} + 1[/tex]
What is your S in this case?
Well I called it EVT because you talked about the extreme value theorem. It is a lemma in my book.
Hmm.. BW is the same as EVT? I don't see it! BW talks about sequences while EVT is about well functions. I understand that we can look at f(x_n) as a sequence but I don't see how this relates to a bounded sequence having a convergent subsequence. In fact, BW and completeness is used to prove EVT so I really don't see the direct relationship.
Dickfore said:
Why?
EDIT:
example:
The first line of my proof states the assumption that lim(x-> infinity) f(x) = infinity. Which implied that the leading coefficient is positive.
Did you read the proof ? S is some set of x's...
Since the behaviour of f(x) is to approach positive infinity as x gets very large or small I know that the x's such that f(x) <= 0 cannot be unbounded below.
Edit
Keep reading the proof.
I said that if f(x) > 0 for all x then I will replace f(0) with zero in my initial S.
Yes, I read the proof. My example is an even degree (second degree) polynomial. Your set S is defined as the values for x for which the function is not positive. What is this set S in my particular example? Is your claim about the boundedness of S justified?
But, I don't. Convince us.
Review my edit.
Well if S was unbounded below it means that for, x in S, if x is in any neighbourhood of -infinity then f(x) <0. Which is contrary to my assumption that f(x) gets large as x gets more and more negative.
In my original proof I should have replaced zero with f(0) in the beginning. I did it at the end which was not so logically sound. The proof can to me in peices so as I was typing the proof out I started to notices gaps and I filled them up at the end. I have to admit, I should have organised the proof a lot better.
EVT is BW applied to a compact interval in the real numbers. EVT is corollary of BW. I don't know why I'm saying this. You already said it.
Ok. So where do you use the set S in your proof?
I used S to define A. Did you actually read the proof? lol
ok, great job.
I think I see it now.:-)
With BW i could take the range of f on [a,b] and form a convergent subsequence to the max and min of f on [a,b]. Is my thinking correct ?
I am a bit slow today and it's 12:03 am lol.
Dickfore said:
ok, great job.
Thanks for been critical with what I wrote. Next time I would try to make the proof more coherent.
Basically. You'll probably see it really easily tomorrow. Suppose f doesn't have a max. Can it really then be continuous?
No. Since it won't be bounded on the closed interval.
Is something wrong in my previous answer. You said basically XD. So was I wrong?
You mean is something wrong with this reasoning? You certainly haven't finished the thought. And you are trying to prove there IS a max and min. You can't really start the proof by assuming there is a sequence converging to the max or min.
Well I guess I can use monotone subsequence property to find a monotone sequence converging to the max or min. As long as f is continuous, then it is bounded; so I can actually talk about locating a max and min.
I thought you were trying to prove that a continuous function on a closed interval is bounded (EVT). Perhaps not?
No, actually. Well in my book the proof that a continuous function is bounded is separate from EVT. i.e they are two different theorems.
Basically, all I am trying to do is see the relationship between BW and EVT which you talked about. You said they are equivalent but I do see it directly.
I just meant that the guts of the proof of the EVT is BW added to the definition of continuity. That's all. Not that they are somehow formally equivalent. And yes, your proof was on the right track. I was thinking EVT was the continuous function bounded theorem. Just confused.
