Can someone me out with free body diagrams
The discussion revolves around analyzing a system involving a pulley and two masses, focusing on free body diagrams and the forces acting on the bodies. Participants are exploring concepts related to static friction, tension in the rope, and the implications of Newton's laws in this context.
  • Participants are questioning the setup of the pulley system, including the attachment point of the pulley and the implications of relative motion between the masses. There are discussions about the correctness of the forces depicted in the free body diagrams and the application of Newton's third law. Some participants are also exploring the relationship between the applied force and the tension in the rope.
The discussion is active, with participants providing insights and clarifications regarding the forces involved. Some guidance has been offered on the correct representation of forces in the diagrams, and there is an ongoing exploration of the implications of static friction and tension. Multiple interpretations of the problem are being considered, and participants are engaging in a constructive dialogue.
There is mention of potential confusion regarding the notation used for the masses and the forces acting on them. Participants are also addressing the implications of the system's motion and the conditions under which the forces balance.
mystmyst
**a horizontal force with magnitude A is acting on a pulley as shown. the two masses p and P are moving together, same acceleration. p is trying to fall to the left but the tension from the rope and the static friction is keeping it in place.
Everything else you need to know is in my two images:
[PLAIN]http://img153.imageshack.us/img153/2193/mymechanicsquestion.png
Free body diagram:
[PLAIN]http://img14.imageshack.us/img14/7249/isolatedstatic.png Thanks!
hi mystmyst! :smile:
(first, i don't understand what the pulley is attached to … and if the blocks aren't relatively moving, how can there be any tension in the rope? :confused:)
(1) you can always do either separate diagrams (and equations) or a single one; if there's no relative motion, there's no point in separate diagrams
your NP down is wrong, an fbd should only have the forces on the body, so only the upward force in this case (and anyway Np = NP … Newton's third law)
btw, use m and M not p and P … p and P are too similar, especially in handwriting :wink:
(2) yes, if the pulley is frictionless, the tensions are the same, and if there's no acceleration then A = 2T
(3-5) i don't really understand your questions
anyway, a friction force goes on the diagram in exactly the same way whether it's kinetic or static
A horizontal force with Magnitude A is acting on the pulley.
Since there is static friction between p and P, the bodies are moving together.
p is trying to fall off to the left but the tension from the rope and the friction is keeping it in place.
1) what is relative motion?
Why is my Np down wrong? Np is acting upward on the large mass which means it has the equal reaction downward for the small mass. Newton's 3rd law?
2) So, even though the bodies are moving, does A=2T? or does it must mean that A > 2T since if A=2T then the bodies wouldn't be moving?
3) u answered
4+5) I am asking if those vectors are correct. It's another Newtons 3rd law of motion. since there friction to the right on the small mass, there's frictoin to the left on the large mass. and 5 is, since there's frictoin on the large mass to the right, there's frictoin on the ground to the left. I'm asking if that's correct.
yes, but what is the axle of the pulley attached to? :confused:
or is it completely free, except that A is pulling it?
i meant, if one block is moving relative to the other block
you can't have both force on the same diagram: one is on the body, the other is from the body: you can only have forces on the body
moving never matters in a force diagram, only accelerating
if there's no acceleration, the forces will sum to zero (A = 2T)
yes, the friction in the diagram for one body will always be equal and opposite to the friction v in the diagram for the other body :wink:
O. I think I get it. The N_P down is wrong for the small mass but I should have a N_p down for the large mass.
Yup! :biggrin:
yay tiny-tim! you rockk!
PF should really get a thank you button. and also a like button...
  • · Replies 34 ·
  • · Replies 19 ·
