What is the Charge on a Capacitor in an RC Circuit?
The discussion revolves around calculating the charge on a capacitor in an RC circuit, specifically with a 2.2 kOhm resistor and a 0.001 microF capacitor connected to a 10V source for a short duration.
  • Participants discuss the application of the charge equation for capacitors and share their calculations, questioning the accuracy of their results and the assumptions made regarding time constants.
There is an ongoing exchange of recalculations and clarifications regarding the expected accuracy of the results. Some participants have provided corrections and insights into the calculations, but no consensus has been reached on the final answer.
Participants are considering the implications of time constants in their calculations and the expected precision of their answers, which may influence their approach to the problem.
musiliu
An RC circuit is made of a 2.2 kOhm resistor and a 0.001 microF capacitor.
The circuit is connected to a 10V source of emf for 5 x 10^-5 s. What is the
resulting charge on the capacitor after that?
Q(t) = -ECe^(-t/RC) + EC , where E is the emf and C is the capacitance
it seems like a simple plug-in problem, so I used E = 10V, C = 1 x 10^-9 F, R = 2200 Ohms, and t = 5 x 10^-5 s.
edit: oops.. i did the calculation wrong.. now i get:
Q = 2.27 x 10^-11 C
is this answer correct now and did i do the problem correctly?
The method looks okay but I get a much larger answer, on the order of 10^-8. Did you get EC = 1 x 10^-8 ? RC = 2.2 x 10^-6?
The 5 x 10^-5 seconds is at least two time constants, so the first term should be just about zero.
ok.., i recalculated and now i get 1 x 10^-8 C... is this correct? is it exactly 1?
No, it isn't exactly 1. That would only be one digit accuracy. Likely you are expected to have 3 digit accuracy, meaning intermediate steps must keep at least 4 digits.
ok..., i used a graphing calculator now and i get
9.99 * 10^-9 C... is this correct?
Oops, you're right and I dropped a power of ten. Correct answer!
9K
