| New Reply |
Closed continuous surjective map and normal spaces |
Share Thread |
| Nov20-10, 03:51 PM | #1 |
Recognitions:
Let p : X --> Y be a closed, continuous and surjective map. Show that if X is normal, so is Y. 3. The attempt at a solution I used the following lemma: X is normal iff given a closed set A and open set U containing A, there is an open set V containing A and whose closure is contained in U. So, let A be a closed set in Y, and U some neighborhood of A. By continuity, f^-1(A) is closed in X, and f^-1(U) is open in X. Further on, f^-1(U) is an open neighborhood of f^-1(A), since it contains f^-1(A). If we apply the lemma above to these sets, we can find an open set V which satisfies the criterion, since X is regular. Since p is a closed map, the image of Cl(V) is closed, and since all the inclusions remain preserved, Y is normal. By the way, just to check, the requirement for p to be surjective was because we have chosen a set in Y, and surjectivity guarantees that this set has a well-defined preimage, right? Thanks in advance. |
| Nov21-10, 07:18 AM | #2 |
Mentor
Yes, the idea is correct. But you did use surjectivity in an essential way. Let me point out where: you have the following situation in X:
[tex]f^{-1}(A)\subseteq V\subseteq Cl(V)\subseteq f^{-1}(U)[/tex] By taking the image of f, you obtain [tex]f(f^{-1}(A))\subseteq f(Cl(V))\subseteq f(f^{-1}(U))[/tex] This is not want you want... You want [tex]A\subseteq f(Cl(V))\subseteq U[/tex] This is where surjectivity comes in, since then it holds that [tex]f(f^{-1}(A))=A[/tex]. |
| Nov21-10, 02:31 PM | #4 |
Recognitions:
| Nov21-10, 02:38 PM | #5 |
Recognitions:
Actually, hold on, I just remembered there's a hint in the book - I'll think it through first.
| Nov21-10, 03:36 PM | #6 |
Mentor
Ah yes, I can see there's a hint. I don't think it is possible to prove this without that hint...
What that hint asks you to prove, is actually equivalent to closedness of maps... |
| Nov21-10, 04:46 PM | #7 |
Recognitions:
I think I see how I can prove it with using the hint, but I have problems proving the hint :) I'll continue thinking about it, but it's starting to drive me crazy.
| Nov21-10, 04:53 PM | #8 |
Mentor
You should only use closedness for proving the hint. I'll get you started:
Take U open such that [tex]p^{-1}(y)\subseteq U[/tex]. Then [tex]X\setminus U[/tex] is closed. The closedness of p yields that [tex]p(X\setminus U)[/tex] is closed. Thus [tex]W:=Y\setminus p(X\setminus U)[/tex] is open. Now show that this W satisfies all our desires... |
| Nov21-10, 05:25 PM | #9 |
Recognitions:
p^-1(W) = p^-1(Y) \ p^-1(p(X\U)) = X \ p^-1(p(X\U)), and since X\U[tex]\subseteq[/tex]p^-1(p(X\U)), p^-1(W) is contained in U, right?
Now, apply out hint to the set V, which is open and contains p^-1({a}), for any a in A, we can find a neighborhood Wa of a such that p^-1(Wa) is contained in V. Now, any Wa is contained in p(V), so the union W of all the Wa's along the set A is contained in p(V), right? And hence, in p(Cl(V)), too. SO, the closure of W is contained in p(CL(V)), so W and its closure are the sets we needed to find. Uhh, I feel this is very slippery. |
| Nov21-10, 05:31 PM | #10 |
Mentor
Yes, that seems all correct. There's just one thing: you didn't prove the hint completely: you still need to show that W is a neighbourhood of y (thus [tex]y\in W[/tex]), but this shouldn't give to much of a problem.
| Nov21-10, 05:37 PM | #11 |
Recognitions:
Well W = Y \ p(X\U) contains all the images of the elements in U, right? And some elements must map to y.
| Nov21-10, 05:44 PM | #13 |
Recognitions:
Excellent! Thanks!
Btw, I have a feeling I'll be needing that "hint" on some other problems :) It's interesting how "at a first glance moderately easy" problems can cause a respectable amount of trouble. |
| Nov21-10, 05:48 PM | #14 |
Mentor
Yes, you will need the hint on problem 7 to
and the hint is also used in problem 12, page 172. It's a neat trick and worth knowing about...
| Nov21-10, 05:51 PM | #15 |
Recognitions:
| New Reply |
Similar discussions for: Closed continuous surjective map and normal spaces
| Spaces of continuous functions and Wronskians | Linear & Abstract Algebra | 7 | ||
| Continuous functions in metric spaces | Differential Geometry | 1 | ||
| continuous expansion is surjective | Calculus & Beyond Homework | 2 | ||
| Metric spaces and closed balls | Calculus & Beyond Homework | 7 | ||
| closed set, normed spaces | Calculus & Beyond Homework | 2 | ||
