New Reply
How to calculate the angle of water in a moving beaker
Share Thread Thread Tools
Nov22-10, 02:45 AM   #1
How to calculate the angle of water in a moving beaker?
Say the beaker is moving to the right direction. The water inside the beaker will be tilted to the left. An angle will be formed and how am i supposed to calculate the angle?
Assumed parameters:
F = force applied to move the beaker
a = accelerations of the beaker
m = mass of the beaker
Thanks!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Nov22-10, 03:38 AM   #2
The water surface is determined by the forces that are acting on it. Also, you can assume that the fluid is static (it does not move, and this is valid when the water surface reaches the final position). For static fluids you have only one equation:
grad P=acceleration =>
dP/dz=-g*rho
dP/dx=a*rho=F/m, where rho is the density
Since P is a function of x,z you can write the following expression
dP=(dp/dx)*dx + (dP/dz)*dz
integrate this equation to find the slope
Nov22-10, 03:57 AM   #3
hi masterx,
thanks for your reply. however i still don't quite understand how to get the slope. In your reply, you assumed that grad of P = acceleration. What is P? also, a*rho=F/m. a is acceleration? i though a = f/m? for the 2 eqns i obtained, must i set boundary conditions to find the 2 constants? Thanks agn.
Regards
Siu Kwok
Nov22-10, 04:16 AM   #4
P is the pressure
I made a typo, a*rho=F*rho/m
You could set b.c., but it would not change the slope.
Remember, that the pressure at the water surface is constant, and equal to 1atm.
Nov22-10, 04:32 AM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi siukwok! welcome to pf!
(please don't post the same problem more than once )
here's two more ways to do it …
imagine that the water is ice … at that acceleration, at what angle would the ice have to be for nothing to slide up or down on it?
use the beaker as a frame of reference: that means you must introduce a fictional horizontal "gravitational" force, and you can then apply the usual inertial laws
Nov24-10, 06:00 AM   #6
Hi all,
taking over to ask some questions regarding this question.
MasterX mentioned that:
dP/dz=-g*rho, if i am not wrong, it was derived from bernoulli's equation? By taking beakers frame of reference, the velocity term drops off and P = -rho*gh+Const.
Differentiating, we get dP/dz=-g*rho.
Question here is:
1) What is the physical meaning of dP/dz=-g*rho?
2) How do you know that you should solve the equation in this manner? Taking differentiation of P.
Edit: added should.
Any help will be great. Thanks.
Nov24-10, 07:05 AM   #7
Hi Delzac,
I did not understand your second question.
First of all, the equation dP/dz=-g*rho is not derived from Bernoulli's equation. Bernoullis' equation states that P/rho+g*z+v*2=const.
You may consider the equation dP/dz=-g*rho as a constitutive equation. It simply says that as we move downwards the pressure increases. In the problem with the beaker, the pressure at the surface is equal to the atmospheric pressure. As we move towards the bottom of the beaker the pressure increases. If a person was sitting at the surface of the water, he would only feel the atmospheric pressure. If, instead, he is at the bottom of the beaker, he would feel the atmospheric pressure and the weight of the fluid. The question here is, how do you calculate the "weight of the fluid"? Well, you do not!! You, instead, calculate the pressure.
By the way, if you use Bernoullis' equation for the beaker, you would find that P_bottom=P_surface+g*rho*h. If you solve the dP/dz=-g*rho you will get exactly the same answer
Nov24-10, 07:20 AM   #8
I missed out the word 'should', added it back into the post.
So the second question is:
2)How do you know that you should solve the equation in this manner? Taking differentiation of P.
But we know you didn't. Nonetheless, how did you arrive at dP/dz=-g*rho, or know that the pressure gradient is g mutiply by density?
For me, i was thinking on the line of balancing the forces, much like those static equilibrium question. And for this question, pressure on one side is higher than the other, so the water should move to equalize it. But it isn't since there is a fictitious force acting on it. And can bernoulli's equation be applied here?
Nov24-10, 07:37 AM   #9
As I said, this equation is not derived from Bernoullis' equation. So you do not need to differentiate with respect to P.
Actually, you are right, You need to take a force balance. Are you familiar with the Navier-Stokes equation? This equation is an extension to Bernoullis' equation, when viscosity is important. In the case of static fluid, the Navier-Stokes equation simplifies to dP/dz+rho*g=0 ( in the z-direction).
The water does not move!!! It is static. If the water was moving, I could not use this eqn and I had to either use the Navier-Stokes equation or the Bernoullis' equation.
Nov24-10, 07:52 AM   #10
Nope, never heard of Navier-Stokes Equation, and after checking out the wikipedia page, i am quite sure its beyond me.
I am quite sure that i can derive it from bernoulli's equation though:
[tex] \frac{1}{2}\rho v^2 + \rho gh + P = Const [/tex]
Since fluid is static, v=0.
[tex] P = -\rho gh + Const [/tex]
[tex] \frac{dP}{dz} = -\rho g [/tex]
In this case, how should be go about balancing the force? Its a bit strange. And is the force exerted on the fluid a constant regardless of where the fluid is? If yes/no, how do you show that? As of yet, i can think of any equation that can do this.
And the main question is how we should approach this problem, which i am not very clear with.
Nov24-10, 10:30 AM   #11
Hi,
i don't think the solution below is correct. But i managed to get an answer which is within my desired range. Please take a look.
Assumptions: Fluid is static
Gradient P = acceleration
dP/dz= -gρ
P = -gρz+c
dP/dx= a_x ρ=Fρ/m
P = a_x ρx+c_1
Making use of the air flow gun which gives impulse = 2.86 (given),
Thus, let F = 2.86, m=1kg, ρ of water = 1000 kg/m3, g = 9.81m/s2
dP/dz= -9810
P = -9810z + c ---------------> (1)
dP/dx = 2860
P = 2860x + c1 ---------------> (2)
To simplify the problem, assume c & c1 = 0, <--------i know that this looks wrong but i couldn't find a way to find the constant.
Let (1)÷(2) :
-9810z/2860x= 1
Gradient of water = z/x = -2860/9810 = -0.29
tanθ = -0.29
θ = 16.2ᵒ
Nov24-10, 10:41 AM   #12
You answer is correct. I tried to derive everything from first principles and arrived at
[tex]\theta=\arctan\frac{a}{g}[/tex]
However, I arrived at this answer with a help from a different problem. What I still don't quite get is why you can just add up these two
dP/dz=-g*rho
dP/dx=a*rho=F*rho/m
to get
what happened to the negative sign in dP/dz?
Nov24-10, 10:42 AM   #13
You are a little bit confused, and I do not know how to help you.
Lets start with the eqn P=-rho * g * h + const
What is the meaning of this eqn? It simple related the pressure to the depth. Nothing more than that!!
Similarly, dP/dz=-rho*g relates the pressure slope to gravity force.
As I wrote before, this is a constitutive eqn. As such, it gives you the pressure at a certain depth (or height).
When I wrote before that you need to take a force balance, I said that only if you want to prove this eqn.
Here is an example:
Assume that you have a body (cube of area A, height h and density rho_b) submerged in water (density rho) at depth H. The body does not move.
If you do a force balance on the body, you have that gravity is equal to the force exerted by the fluid on the body. Of course, this force is the pressure plus the buoyancy (B).
So, -rho_b*A*h*g+(P_bottom-P_top)*A + B=0 => B=-rho_b*A*h*g-(P_bottom-P_top)*A
and based on the previous eqn, P_top=P_surface-rho*g*H
and P_bottom=P_surface-rho*g*(H+h)
So, B=-rho_b*A*h*g+rho*A*h*g=A*h*g*(rho-rho_b)
Nov24-10, 10:47 AM   #14
Quote by kudoushinichi88 View Post
dP/dz=-g*rho
dP/dx=a*rho=F*rho/m
to get
Because P is a function of x, z. Therefore, you can write that
dP=(dp/dx)*dx+(dP/dz)*dz
Why does the negative sign bother you?
The above eqn simplifies as follows:
1=(a*rho)dx+(-g*rho)*dz
Therefore, the slope is dz/dx=a/g=tan(theta)
Nov24-10, 10:56 AM   #15
huh? where did the 1 come from?
Nov24-10, 11:00 AM   #16
What is the pressure at the surface equal to? It is usually equal to 1 atm.
Nov24-10, 11:00 AM   #17
Hmmm, i think i roughly get it already. Thanks for your help!
New Reply
Thread Tools
Similar Threads for: How to calculate the angle of water in a moving beaker
Thread Forum Replies
Fingerprints though beaker of water Introductory Physics Homework 0
Calculate angle of reflection. Classical Physics 3
Calculate the angle out Introductory Physics Homework 3
Angle of reflection with moving mirror, SR Advanced Physics Homework 5
beaker with water on a weighing scale.... Introductory Physics Homework 4
