Effects of homogeneous and inhomogeneous magnetic fields on particles
The discussion focuses on the effects of homogeneous and inhomogeneous magnetic fields on three types of particles: charged particles, polarized particles, and magnetic dipoles. A homogeneous magnetic field does not exert a force on stationary charged particles or magnetic dipoles, while an inhomogeneous field does exert a force on both types. The Lorentz Force equation, F = qv X B, applies to moving charged particles in both field types, demonstrating that the field's uniformity significantly influences particle behavior. The neutron, as a polarized particle, is unaffected by a homogeneous field but responds to field gradients due to its magnetic moment.
  • Understanding of Lorentz Force and its application
  • Familiarity with magnetic moments and their effects on particles
  • Knowledge of magnetic field gradients and their implications
  • Basic principles of particle physics, particularly regarding charged and polarized particles
  • Research the implications of Lorentz Force on various charged particles
  • Study the behavior of magnetic dipoles in different magnetic field configurations
  • Explore the Stern-Gerlach experiment and its relevance to polarized particles
  • Investigate the mathematical modeling of magnetic field gradients and their effects on particle motion
Physicists, students of particle physics, and engineers working with magnetic field applications will benefit from this discussion, particularly those interested in the dynamics of charged and polarized particles in varying magnetic environments.
magnetics
Hi,
To understand the difference between uniform magnetic fields and field gradients would it help to make comparisons between their effects on different particles? The posts on Stern-Gelach shed some light here.
For instance, what effect would a homogeneous and an inhomogeneous magnetic field have on the following three particles in both a stationary and moving (constant speed) state – charged particle, polarized particle and magnetic dipole? Would these three particles work best for the comparison?
Thank you.
Yes, that's a good starting point. As the simplest example, a neutron, having no charge, is unaffected by uniform field. However, having a magnetic moment, it is affected by a magnetic field gradient.
So would it be correct to say that for the moving charged particle, both the homogeneous and inhomogeneous fields are going to produce a Lorentz Force = qv X B perpendicular to both the direction and the field. For the stationary charged particle there will be no force in a homogeneous field, but what about an inhomogeneous field?
For a magnetic dipole there will be no force in a homogeneous field, but a force in an inhomogeneous field while moving and stationary according to F = V(m.B), where V is the gradient.
For a polarized particle, the homogeneous field will only produce a torque on the particle if it is not aligned to the field lines. Will the inhomogeneous produce a different force on the polarized particle?
  • · Replies 17 ·
  • · Replies 41 ·
