| New Reply |
Linear Momentum, Impulse, Center of a Mass, Velocity, Kinetic Energy |
Share Thread |
| Nov23-10, 05:50 PM | #1 |
Two ice skaters (m1 = 85kg and m2 = 52kg) in a pairs-skating tournament are both initially holding on to each other while travling to the right at 4.5 m/s. Skater #1 then thows skater #2 to the right in a graceful toss. Immediately afterward, skater #2 is travling to the right at 9 m/s (ignore friction). a. What is the final velocity of skater #1? Is it to the right or left? b. What was the change in total kinetic energy of the skaters due to the throw? Was net kinetic energy gained or lost? c. If the throw took .5s, what was the magnitude of the impulsive force on skater #2? d. Was the impulsive force acting on skater #1 was less than, the same as, or greater than the force on skater #2? e. Find the final velocity (after the throw) of the center-of-mass of the two skaters. 2. Relevant equations Not sure 3. The attempt at a solution a. I thought skater #1 would be traveling at 2.25 m/s to the right. If he threw skater #2 as to increase her speed by half, then his speed should be reduced by half. Didn't understand the rest of the questions. |
| Nov23-10, 06:03 PM | #2 |
Hi DMRika! Welcome to PF!
![]() ![]() Use conservation of momentum |
| New Reply |
| Tags |
| center of mass, impulse, kinetic energy, momentum, velocity |
Similar discussions for: Linear Momentum, Impulse, Center of a Mass, Velocity, Kinetic Energy
| Confused about the difference between impulse momentum and kinetic energy | Introductory Physics Homework | 3 | ||
| Center of Mass/Linear Momentum | Introductory Physics Homework | 2 | ||
| Center of Mass and Linear Momentum | Introductory Physics Homework | 8 | ||
| Center of mass & linear momentum help please | Introductory Physics Homework | 9 | ||
| Calculating mass and speed from kinetic energy and linear momentum | Special & General Relativity | 12 | ||
